FS: 2021 F350 Lariat Tremor, Flat Bed, Cirrus 620 Adventure Mobile ($140,000)
Testing the market, pre-listing since I'm still using the rig then will need to clean it up and get it dialed before the actual sale.
CURRENT LOCATION: Denver, Colorado (Currently stored in Silverthorne, Colorado while I'm out of the country)
ASKING PRICE: $140,000
2021 Ford F350 Lariat Tremor
  • ~20,000 miles, will have more as this is still my primary vehicle.
  • 7.3L Gaszilla
  • Black exterior, Black leather interior
  • Tremor Off Road package with 35" tires, shocks, crawl mode, etc.
  • Lariat Black Appearance, Lariat Ultimate package, plus all the gizmos you can select on this trim
    • 4.30 Locking Axle
    • 11,300# GVWR package (i.e. you can build this thing out to be significantly heavier than it already is and be within legal limit)
    • Panoramic Sunroof
    • Power running boards
    • Dual battery, dual alternators
    • Heated & Cooled seats
Truck Customizations
  • OEV Aluma Tray Flat Bed, 6.75' w/ 4x undercarriage boxes, 2 lengthwise storage boxes, and trundle drawer ( Overland Explorer Aluma Tray – AT Overland Equipment)
    • Backup sensors have been moved from original bed to flat bed and work like magic.
    • Backup 360 Camera has been replaced by an OEM 360 Camera mounted to the flat bed, making backing up easy as pie
    • Did not keep blind spot sensors, thus missing OEM functionality
  • 2x Baja Designs LP9 Amber
  • Baja Designs Fog Pocket Kit - 4x BD Squadrons (2x SAE, 2x Flood)
  • 2x Baja Designs XL80s on A-pillar mount
  • 2x Air Lift LoadLifter 5000 Ultimate Ford 2020+ F250/F350 airbags (plumbed to the rear of the flat bed for easy access, manual fill/empty)
  • Via Air 20185 Dual Compressor & Tank air system, plumbed to the top of the flat bed for easy access, with all accessories including 30' coiled air hose
  • All customizations are wired to the OEM aux switches in the cab.
Camper
Camper Customizations
  • 200Ah 12V Lossigy LiFePO4 Battery - camper came with an awful, small led acid battery. This Lossigy battery is amazing because it crams 200Ah in a very small form factor that fits in the camper's original battery compartment.
  • Victron SmartShunt - Bluetooth Battery monitor ( SmartShunt - Victron Energy )
General Info
  • Just a smidge under 11' tall.
  • Average 12MPG with camper over its lifetime. This engine purrs on happily with the lowest octane gas available. This engine also has power & torque for days - this setup with flatbed and light camper doesn't scratch the surface of the payload capacity of the truck & engine.
  • Used for the past 8 months on-and-off for some full-time stints (3-6 weeks in duration) and many long weekends
  • Well cared for, but definitely not perfect.
  • Everything works as expected.
  • The storage from the flat bed is INCREDIBLE.
  • Has a deep scratch / dent in the right rear door from unknown sources while parked on city streets. I will have it fixed and looking like new before sale.
  • Windshield is currently cracked, will have this fixed before sale.
  • Truck title clean in hand, all other paperwork also available (camper, flatbed, maintenance).
Random photo gallery of camper (on old & new truck) and truck:
PHOTOS.
WanderingBison
I would live to hear more about the replacement OEM 360 cameras, if you’re so inclined to help me understand what’s possible with a flatbed on a SD.
Seems like a great setup - good luck with the sale!
Thank you!
As for the replacement camera, this is the kit I got:
2017+ Super Duty w/ 360 view-Relocation kit -Camera included (camerasource.com)
The camera itself is exactly the same camera that's built into the tailgate (in fact, if you are so inclined, you can remove it from the tailgate and save yourself the money. I didn't do that in order to be able to sell the bed in its entirety). The upfitter left the camera cable & connector intact when he removed the bed / installed the flatbed. So it was literally plug-n-play, I mounted the housing from the kit in an easily accessible, central spot on the flat bed and have complete OEM 360 camera / backup camera use. I'll take a pic of the mounting tomorrow morning to give you a better idea. Neat solution.
WanderingBison
Thank you!
Great info. Thank you, and I’d love to see the pictures.
BUMP. Added interior photos of truck and photo of rear/backup 360 camera placement. FYI the camper is off right now in order to get the truck door fixed and both the truck and camper cleaned and detailed. Will post interior pictures of camper soon.
hhlightcap
Hey - nice setup. Would you mind posting some pics of the truck with the camper off? I'm debating building a similar setup on a Tremor and I'm curious how it would look with just the tray and boxes.
Stephen
oskarf150
