Propex 2211 Reset
Mark2457
Hi All
Just about to order a propex and considering the 2211 vs 2000, because I can mount on it's side, I also may install externally.
I know that there is a reset procedure on the 2000 that requires access to the circuit board. Is the same true with the 2211?
Thanks
Mark
glennm01
I used to have a 2211, and the reset procedure required turning the fan on, off, and back on again within a couple of seconds. Or maybe it was off, on, and off again. I forget. Regardless, no need to access the circuit board on the 2211.
NOPEC
Same procedure exactly for a 2000. I have a newer one (post 2018). On the wall controller, start on the fan setting and go to "On,Off,On". Works perfectly.
DanoWall
