**SOLD** SASQUATCH CAMPERS - SLEEP-IN EXPEDTION CAMPER FOR SALE (FIELD TEST UNIT)
Kremer5
Greetings Expedition Portal
Sasquatch Expedition Campers is a startup camp trailer manufacturer set to launch this Spring. We are based out of Silverton, CO at an elevation of 9,318'.
Up for sale is a field test unit for a line of campers we will launch this Spring. This camper has about 5500 miles on it and performed very well on every trip it went on, this is a great unit that proved to be very capable in the backcountry. This is not a back yard build; this trailer was modeled in Solidworks through a collaboration between two Engineers experienced in trailer and race car fabrication, product development and manufacturing.
CLICK HERE FOR PHOTOS
Here are the build details:
  • Independent trailing arm suspension featuring Fox coil overs - Specifically engineered for our expedition trailers
  • Aluminum frame with black powder coat - lightweight and will not rust
  • Renogy 2000W inverter with 110v outlet in the tongue box
  • Renogy 200W Solar charging system with Bluetooth monitoring
  • RVi Towed battery charger
  • BFGoodrich 285/70/R17 All Terrian T/As mounted on Method wheels with full size spare
  • Electric brakes with breakaway
  • Hand parking Brake
  • Ark articulating 2" coupler
  • Ark XO 500 tongue jack
  • Four laser cut custom fabricated side boxes with compression latches and automotive grade seals.
  • Camplux on-demand hot water tank with shower hookup.
  • Tern overland doors, painted black.
  • 7" memory foam mattress
  • Interior recessed lighting, reading lights, USB and 12v power sources
  • Laser cut aluminum interior cabinet system
  • Propex 6500 BTU heater with digital thermostat
  • Two 11 lb propane tanks
  • 30-gal water tank with four baffles installed to prevent water from sloshing around when off road
  • Furrion three burner cooktop
  • Dometic fold down sink with glass lid
  • Stainless Steel Countertop
  • Laser cut aluminum kitchen cabinet system
  • 12v and USB power supply in the kitchen
  • Led lighting both inside and outside of the kitchen
  • Iceco VL60 Pro fridge with stand and 12v power supply that is integrated into the door
  • Fold down stainless-steel prep table built into the spare tire rack.
  • Spare tire rack has integrated button to control rear exterior lights
  • 2" rear receiver hitch integrated into spare tire rack for accessories such as bike racks
  • Floodlights integrated into rear bumper that turn on (low setting) when vehicle is in reverse, and can be turned on using a button that is integrated into the spare tire rack for lighting up your campsite when needed.
  • Rear recovery points with shackles.
  • Accessory racks on each side of the trailer to mount items such as Rotopax, recovery equipment (shovels, axe, Maxtrax), etc..
  • Laser cut roof rack with four 1"x2" aluminum cross members, powder coated black
  • 13' Length, 75" width, ~1700lb dry weight
  • 48" x 75" x 7" memory foam mattress inside a 48" x 80" cab
The entire unit is powder coated with the exception of the lower front tongue box and the trim around the door. These are painted as they were reworked during the build to provide better fitment through an improved design. The interior is composite lined, no wood was used for this build.
This trailer will retail for $42,500 and is listed for sale at $29,000. The 23Zero and Rotopax accessories are not included in the price, but we can also quote them if interested. We are willing to discount the price for someone local to Southwest Colorado so we can service the camper when needed and stay in contact as the unit get more use.
We are happy to go through it in person or on video, please DM me with questions. Thanks for looking.
Kremer5
Is there an onboard water tank? If so what is capacity?
Yes, there is a 30-gal on-board water tank. It has four baffles installed inside to keep water from sloshing around, keeping your center of gravity low when pulling it off road.
No members online now.
