CURRIE HIGH PERFORMANCE REAR AXLE
Trudogtrails
Currie manufactured 9" ring gear, high pinion, rear axle 35 spline full flouter rear differential complete, built for rock crawling, off-roading and or overlanding! Universal piece to fit a ton of different vehicles so it just depends on what someone is using the piece for. DM with any questions…
condition: new
delivery available / location is Puget Sound Area
make / manufacturer: CURRIE ENTERPRISES INC.
model name / number: Currie Rear Axle
size / dimensions: 69.5" WMS-WMS
cost / $7000
Specifications;
• Full Float
• Complete with 5.29 Gears
• ARB 35 Spline Air Locker
• Wilwood Disc Brakes
• Full Length Back Truss
• Drain Plug Equipped
• Large Red Currie Fill and Inspection Cap
• Differential Skid Plate for 9” Third Member
• 6 on 5-1/2” Floater
• Hub Kit with 5/8” Wheel Studs
• 35 Spile Axles
• Wheel Mounting Surface Dimension of 69.5”
• Never Has been Used
• No Lead Time of 3-6 Months!!!
• Shipping Can Be Arranged If Needed
Trudogtrails
What vehicle was it originally destined for?
Sent from my SM-G973U using Tapatalk
Originally intended for a 2016 Toyota Tacoma however it does not have ABS sensor mounts and was not worth the fight to make it work, therefore would prefer to sell it to someone who can use it now, or I save it for a future build
flipstick
