Sold: 2019 FWC Hawk For Sale: 2018 F150
We are selling our 2019 FWC Hawk + 2018 Ford F150 located in Denver. Both are very clean and non-smoker.
2019 Hawk shell with rollover couch
Silver spur exterior
Yakima roof rack including lockable towers and bars
Diesel heater with external fuel tank
Jack stands with aluminum mount
Thermal pack
2 fantastic roof fans (1 powered, 1 passive)
Turnbuckles and mounting plates
Wooden dolly to pull it in the garage.
It has been stored inside any time it wasn’t in use. Everything works. It has one small bend in the roof (forgot to unclip!) but is a smooth bend so is still 100% waterproof.
Factory sticker says 945 lbs
Gray 2018 Ford F150 XLT extended cab. 4x4, 3.3L V6 engine, 44k miles. Small dent in rear bumper.
Selling together for $49,800 or camper for $18,500 and truck for $31,800.
Please fire away with questions or for more pics!
How did you run fuel from the rotopax to the diesel heater. What parts did you use?
Drilled a small hole in the bottom of roto for the fuel nipple that came with the heater. Could also use a downcomer and not need to drill the hole. Fuel shutoff valve and a few 3m command hooks to hold the fuel line in place next to the camper, and two 1/4" holes in the side of camper. One to run line to the pump and another for the line from pump to heater fuel inlet. The nice thing is it is almost entirely removable, with the exception of the hole for the heater intake and exhaust. Hooking up the exhaust is done thru the turn buckle access
