I've been told (but not read the specs) that a Propex is more efficient with electricity use as well as propane use. It is the power consumption that is our greatest limiting factor.Are you sure a Propex is more efficient, and is efficiency that important when you can carry 40 lbs of propane? I would be really reluctant to pull out the Atwood in my Escape 17B personally unless it was a noise issue. Just curious what your reasoning is there.
The set ups in the Escape just blow out the front grille for supply. No ducting. They are small inside so it works.
But yeah that power consumption.
So, kind of wish I did this.Take a really close look at the torsion axles. Run a straight edge across them see of they are square so you don’t burn through a tire or two from alignment issues?.
Looking forward to your trip report would love to get up there in that region. Have read lots of great trip reports about it.
Oh dang. Hopefully it didn’t screw up your trip? I’m still waiting on the stupid prices to crash. Going to look at a Airstream 23CBB next week for another idea err possible option. Getting my parking area sorted so I can jump on the epic RV market crash looming ?.So, kind of wish I did this.
One tire comically worn outside edge, 3 other tires fine.
I have seen many loose bolts on the wiring side in a few different brands. Probably a combo of sloppy work and road vibration in many cases. Road vibration definitely will rattle everything loose at some point.So, last year I found a nut missing on a wire with a ring stud on some sort of thermal safety. The tention of the wire wanting to curl up and the teeth of the stud managed to hold it in place. Escape shipped me the nut and I put it on.
This year, the EMS gave me a reversed polarity error. I checked the power point with a cheap meter and it was indeed reversed. But since I was checking around I opened the EMS to check everything and found more sloppy electrical.
On the contactor, the neutral side terminal for the smaller gauge cables wasn't tightened down, instead tension of the wires kept it jammed against the main neutral wire that was actually clamped into the contactor. Very hard to take a pic.
Fixed that before it became a problem.
This one was straight up never there. The rubber stud cap was on, but no nut.I have seen many loose bolts on the wiring side in a few different brands. Probably a combo of sloppy work and road vibration in many cases. Road vibration definitely will rattle everything loose at some point.
Ha newbie’s first Friday on the line.?♂️This one was straight up never there. The rubber stud cap was on, but no nut.
YepIt's coming!
I'm looking for a Northern Lite 10-2 Camper. In the spring everything was pre-sold and 5yo used was 70% of new. Now dealers have 2 or more NL campers on the lot.
At a RV Show in BC there was 2 NL with "special" show pricing.
The dealer called on Wednesday:
- it was a bad show for all of the dealers
- The NL are less than the show price and they are open to offers
- they've stopped ordering and canceled all the large RV orders.
- financing was 2.99% for the last couple years. It's 7.99% now and going to go up again. Horrible for anyone that has to refinance.
