***SOLD*** SASQUATCH CAMPERS - EXPEDITION CARGO TRAILER (FIELD TEST UNIT)
Kremer5
Sasquatch Expedition Campers is a startup camp trailer manufacturer set to launch this Spring. We are based out of Silverton, CO and have been designing and testing these campers for over a year now.
Up for sale is a field test unit for a line of campers we will launch this Spring. This camper has about 300 miles on it and has been camped in. This is not a back yard build; this trailer was modeled in Solid works through a collaboration between two Engineers experienced in trailer and race car fabrication, product development and manufacturing.
We are offering this for sale at a $10,000 discount at $19,500 OBO, without the 23Zero accessories. If you're interested, these can be purchased at dealer cost with the trailer.
CLICK HERE FOR MORE PHOTOS
Here are the build details:
  • Independent trailing arm suspension featuring Fox coil overs - Specifically engineered for our expedition trailers
  • Aluminum frame with black powder coat - lightweight and will not rust
  • Renogy 1000W inverter charger
  • Renogy 20A DC-DC Battery Charger, wired for low current charging while towing using 7-pin charger
  • BFGoodrich 285/70/R17 All Terrain T/As mounted on Method wheels with full size spare
  • Electric brakes with breakaway
  • Ark articulating 2" coupler
  • Ark 30” Drop Down Corner Steadies integrated into bumper
  • Two CNC cut custom fabricated side boxes with compression latches and premium weatherstrip seals.
  • Camplux on-demand hot water tank with shower hookup.
  • Interior Cargo Area
  • Interior cargo lighting, USB and 12v power sources
  • Bed lined 1/8” aluminum floor installed in cargo area
  • Two 11 lb propane tanks
  • 30-gal water tank with four baffles installed to prevent water from shifting weight around when off road
  • Furrion three burner cooktop
  • Fold down sink with glass lid
  • Stainless Steel Countertop
  • Laser cut aluminum kitchen cabinet system
  • 12v and USB power supply in the rear of the passenger side box
  • Led lighting both inside and outside of the kitchen
  • Iceco VL60 Pro fridge with stand and 12v power supply that is integrated into the door
  • Fold down stainless-steel prep table built into the spare tire rack.
  • Spare tire rack has integrated button to control rear exterior lights
  • 2" rear receiver hitch integrated into spare tire rack for accessories such as bike racks
  • Floodlights integrated into rear bumper that turn on (low setting) when vehicle is in reverse, and can be turned on to the high setting using a button that is integrated into the spare tire rack to light up your campsite when needed.
  • Rear recovery points with shackles.
  • Laser cut roof rack with four 1"x2" aluminum cross members, powder coated black
  • RotoPax 4-gal gas tank mounted to spare tire rack
  • 12' Length, 75" width, ~1100lb dry weight
We also have a sleep-in version that is available here: SASQUATCH EXPEDITION CAMPERS - SLEEP-IN EXPEDTION CAMPER FOR SALE (FIELD TEST UNIT) | Expedition Portal
jlowens
Looks pretty good...
Some questions:
1. is the rear receiver rated? we have a heavy duty 6 bike rack that by itself is ~80 lbs...
2. is the sink plumbed for both hot & cold water? how does the sink drain?
3. are all the water fittings/tank/pipes potable?
4. What is the hub pattern (I have an LC200: 5x150, 110 mm center hub)?
5. What is the track width?
5. Could you PM dealer cost for the tent and awning?
Thank you!
-Jason
Kremer5
Thank you!
I'll PM you my Email address in case you have more questions.
Some questions:
200 lbs is the hitch rating. Can you send me the model of bike rack you have?
The sink is plumbed for both hot and cold water and drains directly out of the bottom of the sink.
Yes
The hub pattern is 5x127, we can help you find an adaptor and the correct offset wheels to get you setup the same as your tow vehicle
74.5"
Sure thing!
Thank you!
-Jason
Kremer5
What is the height on this with a RTT attached? and is the awning height adjustable?
The height with a 23Zero RTT is 83"
The awning brackets are not height adjustable; they were designed to hold the RTT window awning poles while the 270 awning was fully open.
iStan814
