Need to replace my 06 Taco: is the 2022 TRD Off-road worth the extra cost?
Switch
After 16 years, its time to replace my 06 TRD Off Road Tacoma. This wasn't planned but accidents happen & so here I am starting a new build. My 06 had custom skids, sliders, & bumpers, a high pinion Currie rear axle, lockers front and rear, and was re-geared to run 35" tires. Rear suspension was OME Dakar springs w/ add a leaf , shackle flip, 14" Bilstein's on custom hangers, & front suspension was Fox 2.5 coil overs, Total Chaos UCA and LCA. This is just to give you some idea of what I'm used to:
So the first decision is to start with the TRD Off Road or the SR model for my next build.
The main things the TRD has that the SR does not have are:
Rear differential locker
TRD Off-Road tuned suspension with Bilstein® 205shocks
One of the first things I'd do is swap these out for a 3" lift, including TC UCA, Dekars, U-bolt flip, Timbren bump stops, and probably a shackle flip​
Crawl Control (CRAWL) with Multi-Terrain Select (MTS)
This is a major unknown. I never saw the need for a crawler box, cause my build didn't go in that direction. Homework needed on my part.​
[Edit: since I posted this I found some demos of crawl control]​
Seems like an improvement over a front differential locker​
16-in. machined-contrast alloy wheels with P265/70R16 tires
I plan to use these as my winter tires for ski trips and run 33" BFG KM2 for wheeling in the summer - unless I re-gear again for 35" tires).​
120V/400W 181 deck-mounted AC power outlet
I never used this cause you had to have the engine running. I just added AC converters where I needed them.​
Projector-beam headlights with LED Daytime Running Lights (DRL) and integrated wide-angle fog lights
I've used this and it is a very nice feature.​
Technology Package—includes parking sonar and Blind Spot Monitor (BSM) with Rear Cross-Traffic Alert (RCTA) (requires colored-keyed rear bumper)
These are real nice to haves. If I do a custom rear bumper - will they still work? I need to talk some bumper shops.​
Tire Pressure Monitor System (TPMS) with individual tire location alert
I have a tire gauge for when I air down/up my tires.​
LED Headlights and Fog Lights
Hum, replace with LED bulbs whey the burn out? I hate that the factory fog lights can't be turned on with the key out of he ignition, so a 2nd set of fog lights go on no matter what.​
TRD Premium Off-Road Package (Access Cab)—includes heated front seats, auto headlights, Premium Audio, Dynamic Navigation with 3-year trial, Remote Connect with 1-year trial, Destination Assist with 1-year trial, and Service Connect 91 with 10-year trial​
-only thing here that I like is heated seats, I'm a skier & oh those cold early rides to the slopes...​
8" vs 7" touch screen​
10-way power-adjustable driver’s seat including 2-way lumbar support
inclinometer with roll/pitch displays
Smart Key System on driver and front passenger doors with Push Button Start
I've probably missed something.
[edit] I missed plenty but this gem is important:
Differential ratio (automatic transmission) 4.3 for the SR, 3.909 for the TRD - this is NOT due to the difference in tires - they are practically the same diameter. BUT the rear differential on the SR is 8" vs 8.75"
Here's the comparison from Toyota's website: https://www.toyota.com/tacoma/features/mpg_other_price/7552/7558/7562
The difference in price between the SR and the TRD Offroad that I have been able to find locally, is $10,000 ($38K vs $48K)
On my 06, I removed most of the TRD stuff (including the stickers) within the first 4 years. So I'm thinking that I should start with the SR model & then I've got $12K in the bank for mods. On the other hand, with the insurance from the old Taco, I can afford the TRD and still be able to make mods over time.
I guess I should mention that do a lot of winter driving for ski trips, and the rest of the time I use it for exploring & camping. It sees mostly moderately difficult trails off-road but some difficult trails too. Think: Death Valley & not the Rubicon.
So I guess I'm trying to figure if I should start with the TRD Off-road or the SR (or SR5). If I'm going to be making mods, am I throwing away good money by starting with the TRD or would it still be with the extra money as a starting point?
Tacomacamper
I got the SR for the reasons you stated. It’s got most of what I want already except for tires and lockers. Just add those (and maybe suspension) and you’re set.
dman93
I believe the SR5 is now available with an off-road package which includes some of the items from the TRD OR. I saw a video about it on TFL but now I can’t find that configuration on Toyota.com.
Does the TRD OR package also come with dual climate on the Tacomas? I have a TRD OR Tundra SR5, and the OR package comes with dual climate as well. That definitely comes in handy when your wife wants it 5-10º warmer on her side.
If this is going to be a daily driver, if you’re going to use the extra features, and if you’re going to keep the truck for a long time, I’d drop the extra coin up front and build it out a bit slower.
plh
What is the availability of the TRD? around here they are difficult to get without a long wait (several months) and dealer premium.
kwill
I think the crawl control and MTS are mostly useless but the rear locker is hard to give up. I went from a TRD O/R Tacoma to an SR5 4Runner. So far the ATRAC system has met my needs but I don't do heavy duty rock crawling.
DaveInDenver
Middle Income Semi-Redneck
I think the only real benefit to TRD OR is the locker.
But it's not so great that I'd buy a new TRD OR. I only went with mine because I was looking used for a stick shift and it was one of the first decent ones I came across. I've done suspension, put on bumpers, dual batteries. So there's not much left to really make it a TRD anyway.
If I had flexibility or was buying new it would be SR for sure and put in an Air Locker. Down side is needing a compressor but I think the ARB locker is otherwise pretty much the same as the Toyota e-locker in most respects like strength and reliability.
One thing about the 3rd gen TRD is the axle and locker are different than what we have in our 2nd gens. Ours are derivative of the standard 8" Toyota axle while the new truck has that 8.75" axle that's supposed to be pretty good and the locker is a new design that might be better (like less vulnerable to actuator issues).
SDDiver5
Given the extent of your prior build, go SR and then mod as you desire? I've always felt the TRD Pro and OR were pretty over priced for what you got. Plus, aren't they hard to find these days? My buddy went to a Toyota dealership to drive a new taco and tundy to see which he wanted and apparently everything they had was spoken for and he couldn't even test drive them...
Another thought- Would you venture to a Ranger Tremor?
PirateMcGee
Have you driven one? The drivetrain is miserable in my opinion as well as the comfort. I tried hard to like it but just couldn't do it.
phsycle
Drive the auto first. You may not like it, as many out there don’t. There are software programs that may help it, though.
If you want stick, you have to get a TRD.
Personally, I would only get a stick in the Tacoma so it would be a TRD. But if the stick were available in the SR, I’d get that instead.
If you still want an auto after the test drive, I’d say SR and pocket the money. Mod as necessary. Stock rig, good tires, and maxtrax gets you to lots of places.
MTS is more of a gimmick. I used it once to test it out and never did again.
DaveInDenver
Since the prevailing opinion is strong about how bad the V6 + auto is it's going to send a few into a hater tailspin when I remind everyone that an SR gets one option - the 2TR 2.7L 4 cylinder + auto.
phsycle
In my region, SR in AC gets 2.7L 2wd/4wd and 3.5 2wd/4wd. The DC gets 2.7 2wd and 3.5 4wd.
DanoWall
