Gvw tag on a hard side?
Mickey Bitsko
Interested in a 8' hard side slide in truck camper and trying to determine dry weight.
Factory tag reads 2350 gvw.. doesn't make sense.
If I walk back typical payload ie; two adults, gas, food etc. Approximately
5-600lbs , that would make dry weight 1700-1800?
Any suggestions?
jadmt
ignore button user
if you are talking about the weight of the camper the weight on the camper tag is usually with water and propane and nothing else. I have never seen a camper include people weight or food etc in gvw. I have also found everything is usually heavier than what the tag says if you actually weigh them.
Mickey Bitsko
Correct, but never seen a tag that reflects gvw on a slide in camper.
Just seems very odd. Could be this particular manufacturer does it this way.
Rv manufacturers fudge weight? ?
dhuss
