Conqueror UEV-310 *Excellent Condition*
outbound_clan
Selling a 2019 Conqueror UEV-310 $18,000. Located in Phoenix, AZ
*Excellent Condition - Used Once*
This camper is every bit as tough and rugged as a comparable Turtleback or Patriot, at a fraction of the price!
With over 18 cubic feet of lockable storage space, a huge 6.5' x 6.5' king-sized bed, and a fast and easy tent setup, the UEV-310 is capable of catering to anyone who wants to get away for the weekend or longer. Lightweight and versatile, featuring a 24 gallon tank and a low center of gravity, the UEV-310 will tow happily behind almost any 4WD vehicle, and can go almost anywhere. It has all the space you need for your overland and camping tools and equipment, and will make a most welcome companion to your adventures.
Unit has added kitchenette with table and sink, as well as 2 burner camp stove. Also features an on-demand propane water heater with shower head for hot showers any time. A true comfort.
Suspension, Chassis and Brakes:
Dry weight 1,500 lbs
GVWR (with max load) 3,200 lbs
3,500 lb torsion axle suspension
Max Coupler off-road coupler
Electric Brakes
Removable jockey wheel
Hot dipped galvanized chassis
LED rear tail lights
Adjustable Stabilizers, to stabilize unit when leveled
Exterior Features:
Massive nose box – 300L
Four side access doors and rear door
All body parts are electro galvanized and epoxy powder coated
Mountings for axe and spade
Axe and spade
Eyelets for fastening of cargo to lashing rails
Groundsheet 5.6 x 2.4m
Midgey netting in windows
Esperia level 2 Intelligent Power Management System -110v
Hella Plug
Water tank 90L
Amenities:
4 Sleeper 2.1m x 2.1m size bed
High density foam mattress, covered in durable Conqueror branded covers
Conqueror Branded Bed linen, fitted sheets, covers, pillow and pillow cases
All tents made from military grade rip-stop canvas
Less than 5 min set-up time for tent
4 Wolf pack (plastic storage boxes) on sliders
Underbed storage shelf
Large mild steel powder coated nose box
Fridge slider 85L Snomaster fridge/freezer with removable baskets - Stainless Steel
Kitchenette w/ sink and table, stove on-demand hot water w/ shower head
Jachi
I’ve run across this situation several times, several folks don’t
bother to even reply to their own post from the get go.
Maybe adds should fade away after 45 days unless renewed..
ABBB
They just blast the ad out to 50 places hoping someone somewhere sees it and buys, some don’t bother, some lose track.
gp01
