Hey Everyone,
Some of you will notice this van as previously being for sale from Zach with Autarky in Reno, NV. I'll make a long story short; I had a 2019 F-450 with a custom flatbed camper shell that was being built out here in Bend, OR. The overland buildout company doing my build moved their business to Colorado while my project was halfway complete and 4 months behind schedule. They acted like they were going to stay true to their word and finish the build but they continued to let me down. I couldn't find anyone to complete the build, but I found Zach with Autarky who had this awesome 2008 E-350. We worked out a trade so that I could have a completed vehicle and he will finish off the F-450 project and it will be for sale.
Now to the good stuff. Zach Reinitz (Autarky) built this Camper from the ground up over the last year. It was his 4th build and most extensive build to date. The van was designed around extreme exploration and ultimate comfort. He acquired a low mileage 4x4 E350 passenger van in Northern California and proceeded strip it down to the core, the new design was re–engineered, Cad designed, and professionally rebuilt into the camper you see today. The van is standard length but packs a ton of features into a compact and powerful package. The shorter wheel base allows you to go anywhere and make tight maneuvers.
Reducing Price - $107,500
Please send me a message to get in touch!
Full set of pictures: Pictures
Summary:
With a robust solar/lithium system, heating system, independent off-grid A/C, indoor and outdoor kitchens, and true off-road suspension this van is incredibly well-suited for a lot of adventures. You could take this van up to the mountain for a ski day or on an overland adventure, it doesn't have a whole lot of limitations.
The Van:
The Camper:
Water, Heat ,Cooling:
Joey
Summary:
The Van:
- E350 Standard length
- 5.4L Triton V8 – 70k miles
- 2008 with a 2020 Passenger Van conversion
- Purchased with roughly 65,000 miles prior to the conversion.
- Total loaded weight is 8200 Pounds
- Total length bumper to bumper is 18FT
- Total height is 10’ 2”
- Fuel economy around 14mpg at 70 MPH
- GCWR of 13,000lbs.
- 3.73 Gear Differential (speedometer almost spot on)
- NV271 Heavy duty transfer case
- Dana 60 Front and rear Axle
- Timberline vans 6” coilover linked 4x4 kit
- Elka 12” travel bypass Stage 3 Coilovers – 500lb Eibach springs
- Bilstein 5100 Rear shocks with Timberline 12 pack rear leaf springs
- Van was originally converted to 4x4 in 2008 by Quad Van of Oregon and was upgraded to the Timberline Coilover kit during the 2021 conversion
- Buschwacker Fender flares
- 17in Method 305s in Bronze
- 33in Kenda Kleaver R/T
- Custom Front and rear Trac Bars
- Front Heavyduty swaybar with extended Links
The Camper:
- Custom R20 Morey Industries Fiberglass Hightop - Interior height – 6’ 2”
- 3m Thinsulate and Closed cell Foam complete insulation of floor, walls, and ceiling- Comfortable far below freezing temps and cools easily in Arizona heat.
- Complete cab and chassis vibration mat with Noico sound deadening
- Marine Vinyl insulated woven flooring
- Stainless steel Entry trim separating camper from driving cab
- Custom upholstered/insulated interior door and window trim
- All Custom lightweight Birch and Bamboo cabinetry
- Isotemp Cruise 49 black Marine 12v /120v fridge/freezer
- Thetford Triple Burner Propane Stainless Cooktop with glass top
- Thetford matching glass top Sink Unit
- Under bed and inside dinette latching storage compartments.
- Rear outdoor Zero Declination Shower Stall with Stainless marine hardware
- Toilet stall with Dometic Compact Cassette toilet
- Dinette Seating with Bamboo table with flush mount wireless phone chargers
- Modular aluminum and Birch bed platform. Bed Extends to a full ( 75x54 )
- 2 piece Temperpedic 3in memory foam mattress
- Custom made memory foam Dinette cushions and mattress wrapped in easy to clean marine vinyl
- Complete dimable LED lighting system with RGBW bed mood lighting flushed into aluminum trim accents on ceiling – with touchscreen controller
- Fresair 12v evaporative rooftop AC
- 5 total Interior 120v GFI Dual outlets with USB charging and wireless tabletop charging
- 12v USB charging stations
- Full pull-out rear kitchen / barbecue unit - Contains flip out propane cooktop and sink with infrared barbecue station.
- Custom door panels with first aid storage / tables / and cutting board
- AudioEngine A2 Bluetooth sound system
- Pedestal rotating passenger seat kit
- Aluminess front winch bumper
- Aluminess rear bumper with hitch receiver and storage
- Smittybuilt 15k front winch
- Aluminess Side mount roof / solar access ladder
- CARR offroad entry Steps
- Complete underside refresh – included media blast and full rubberized corrosion resistive coating.
- Pair of Baja Designs S2 floods on Hood Mounts
- Hella flush-mount bumper Pencil Beam Halogens
- Autarky Standard Solar Kit – AutarkyEv.com
- 300W Flush mount Rooftop Solar array
- Orion 30 Amp Alternator DC to DC charging while driving
- Victron 100/50 Bluetooth Charge controller
- Victron BMS with Shunt – Interior controller
- 2000w Victron compact Inverter Charger with Cerbo controller and GX50 touchscreen
- Midnight Solar Baby box with charge controller and inverter breakers.
- 200 Amp DC disconnect
- 30 Amp 120v interior accessible breaker panel containing all circuits both AC and DC in one easy to access and maintain panel.
- 300ah Ampertime Lithium Battery bank
- All mounted below rear dinette bench seats
- 35 Gallon Fresh water tank – SS marine inlets
- 8 Gallon Grey water tank – exterior Dump outlet
- Shurflo 12v Water pump
- Full Pex Plumbing
- Rear mounted Stainless Shower system – hydronic connected for instant hot showers.
- Rear mounted and enclosed 20lb Composite Propane tank – Only used for cooktops
- Main Gasoline tank connected Eberspacher Ds5 Hydronic system - Instant hot water heat exchanger and Kalori thermostatically controlled in cab water to air heat exchanger.
- Eberspacher easy start pro controller
- Rear bumper mounted all aluminum hydronic tank for easy service
- All plumbing and tanks are mounted within the insulated interior and will not freeze while camper is heated
- Fresair 12v DC Evaporative cooler with separate 8 gallon water tank.
- Custom Gold reflective heat shields for every window in the camper
Joey
