Captain_Coffee
Hi all!
This is my first post and so forgive me if I have placed it in the wrong area or under the wrong heading. I am looking for advice. I have a Smittybuilt Trailer with a Smittybuilt Overlander XL (1st Gen) and we have decided that we will most likely be updating to a hardshell. I really like the Smitty RRT we have, it is by far the best camping experience I have ever had, but it is time to get something smaller since the kids are big enough now to have their own tent. I am getting a little older and want something that is a bit easier to put up/break down. I have been researching for the better part of 6 months and am planning a trip soon (May) to a dealer to see a couple of Hardshell brands available in Texas in person.
I am currently leaning toward a Freespirt Evolution but am not wedded to the brand. I wanted to include my thinking below and see if anyone had advice, suggestions, or comments for RRT hard shells in general. We are looking to pick box style only.
Here is the FRS Evolution I am currently considering:
gofsr.com
Pro's / What we like:
1. Quick Down: It appears that this is an RRT that you can actually close in 5 min ish or less. Most are not like this, and in particular soft shells with covers take a significant amount of extra labor.
2. Top is aluminum: meaning (I think?) it will have more durability for offroading and will not have as many of the possible fiberglass problems. ( cracking due to rocks being thrown up or stress, pulling away)
3. Tri-layer fabric: ( Appears) to be good for heat ( cool in the desert) and Warm in the cold ( can camp in the real cold with snow with reasonable comfort).
4. Tent Roof rack / Side mounting groves: According to the manufacturer it appears that you can use the side groves for some actual roof weight, like bikes, canoes, or luggage racks.
5. Room for bedding and Pillows: You can keep 2 sleeping bags, pillows, and the ladder inside
6. Size: I want to get something that is 55 wide and 70 inches long ( like a full-size bed) at the least
Concerns / Worries about this brand/model :
1. Not easy to pull up and put down. I want the ease of packability. If I cant exit a campsite in 15 to 30 min I could get caught in bad weather. I expect that anyone living anywhere in the Southwest US understands this. You do not always get good warnings on the trail of bad weather or wildfires for example. The amount of stuffing and effort needed to take it down is more important to me than the setup time.
2. Sealed: When traveling in the desert and on the coast sand gets everywhere. I am not against some of it, but if I stop for the night and open up my RRT and have a new layer of dust/sand inside I will be quite frustrated. Also, this means if I have it up and the winds are kicking up to 35-40 MPH like they do on the coast I expect if I leave it closed, it will not have a boatload layer of sand in it. I am worried that the open bottoms on FRS evolution RRT's will allow in the dust while traveling
3 Warm/Cool: I do not camp in temperate areas. I camp in the chihuahua desert and am also planning to take this to Alaska one day. I really want something that is an actual 4 seasons tent. When I called and asked they said they did not have any of the extra insulation layers for purchase that some tents have. I am worried that the "tri-layer" fabric will not hold up well to serious heat or cold. By hot I mean above 95 Degrees and by cold I mean below 32 Degrees F. As a rule we avoid camping if possible below 0 or above 110.
4. Durability: If we drop this kind of money on a tent I expect it to last much longer than the warranty. It has to be able to pay for itself which by my calculations means I need it to work for a minimum of 4-5ish years minimum without a real problem. I camp up to 1/4 or 1/3 of every year. Small issues, like fabric wear that need patches or a different mattress, do not concern me. We also do not store our RRT outside because we want it to last longer. I would count serious problems as something that prevents you from using the tent as it is meant to. Like bending from regular use, not holding up well ( slapping, flapping, and tearing) in the wind, unable to function as meant, susceptibility to leaking/mold, or key components (like hinges or fasteners) that break. The ability to switch out pieces/ clean the tent fabric that has issues would also be great.
5. Foldout components: I do not like them in general, they often require staking and can be tricky in high winds. This is the reason we are leaning toward a triangle or box style Hardshell RRT.
Please share your thoughts either on this model or any other that you know about. I would love any additional input on this issue!
THANK YOU in advance!
Many blessings,
Captian_ Coffee
Evolution Series
Freespirit Recreation reinvented the rooftop tent from the ground up, creating industry-leading designs that elevate your adventure with awesome materials, rad designs, and fast setup times. From extreme-weather Tri-layer tents, to our newest Aspen Lite, Freespirit has the roof top tent for your...
Many blessings,
Captian_ Coffee
