Jump boost for dead lithium battery?
Jard1
i just took my trailer out of storage and both 100amp lithium batteries are dead. Tried a trickle charger but that doesn’t work as the battery is not detected (I suspect the internal BMS shut it off as the voltage is too low). I have a jumppack portable booster (https://no.co/gb40) and wondering if it’s safe to use to try revive the batteries? appreciate any help
john61ct
No.
Very low current input, start very low voltage too like 2.0Vpc overnight then 2.5V then 3.0V and so on.
They may be scrap though, but worth a try.
When batts in storage need to check on them and keep topped up at storage voltage
never Full
and never let drop anywhere near 3.0Vpc, murders lifespan
Really should be able to disconnect the cells from the Battery Murder System
darrylkd
