Liquid Spring Suspension
RAM5500 CAMPERTHING
OG Portal Member #183
Interesting concept that seems to be gaining popularity now.
I considered this when i was trying to choose between this or the Kelderman air setup.
Long story short, repairing a leak or issue with an air system is super easy and mess free with basic hand tools.
Repairing a leak or an issue with a liquid system is complex and messy as hell and likely need some specialty tools
Would need to carry a fair amount of supplies for emergency repairs
No Thank You
My .02
Alloy
Interesting concept that seem to be gaining popularity now.
Long story short, repairing a leak or issue with an air system is super easy and mess free.
Repairing a leak or an issue with a liquid system is complex and messy as hell.
My .02
What do you carry to repair your hyd. brakes?
With Kelderman off road wear and tear is an issue (have you replaced the rod ends / bushings yet) on the mechanical side. How many ambulances use Kelderman?
Liquid Spring doesn't have a dealer network. I'd want to be trained on how to install/setup the system. If I was going to install it there would be a valve on each pump, all the hyd hoses would be the same length so only 1 spare hose is needed and I'd carry caps and plugs.
