Joe917
These guys are incompetent.So the shop that was supposed to look at it Friday, did not and they actually called me Friday night at closing time to complain that they could not get the brakes off and the owners manual is in German ?
There is also a 24V 200 amp alternator available. Our truck had one, the only alternator I have seen with a grease point!FWIW, if you order a new alternator, well worth getting a 100 or, better yet, 150A unit. Bit tricky and, depending on the year, will probably require that you acquire a new plug and do some minor rewiring, but well worth it, especially for camper use.
My original alternator was only 50A.
If it is the alternator, a replacement is available in the USA. Might not be exactly what you want in the end for your finished truck but should get you home. Starters are also available.I figure I’ll uprate the alternator and/or add a second one.
Ultimately, I’m going to be only diesel and solar for power, want a robust electrical system.
Joe, do you happen to have a part number/source for that alternator?There is also a 24V 200 amp alternator available. Our truck had one, the only alternator I have seen with a grease point!
I'd be interested in the dual fan alternator upgrade you did.If it is the alternator, a replacement is available in the USA. Might not be exactly what you want in the end for your finished truck but should get you home. Starters are also available.
This one should drop right in with no wiring changes, Alternator - Mercedes Benz Unimog U-300, U-400, U-500 Truck 2000-2003; ABO0447 | DBE (dbelectrical.com) . I can check if you post your VIN (I'll look it up in the EPC). The Mercedes part number should also be stamped on your current alternator. It is cheap enough that you can buy it for just the trip home, plus they offer $27 overnight shipping upgrade. Swap the pulley out for your current one (easiest with an impact wrench). Then a metric open end wrench set and you are set. Hopefully the shop you are at could charge your batteries?
I also have the wiring instructions for the more modern dual fan alternator upgrade (which we are currently running). It takes a little bit more time and some extra wiring but I think worth it in the long run.
pm sentJoe, do you happen to have a part number/source for that alternator?
