RAM 5500 4x4 Camper Truck SOLD
OverlandFT
Up for a sale is a Ram 5500 “adventure truck” with full off grid camper setup.
Price: $54K SOLD
Truck:
2011 Ram 5500 Single cab, 115K miles
6.7L Cummins
6 speed G56 manual transmission
4x4, 4 high/4 low manual shifter
5 aluminum 20” super single wheels, 335/80R20 Pirelli tires, bead balanced
Standard suspension, 1.5” lift, AEV high mark fenders
10” android head unit with backup camera
On-board air, belt driven air compressor with pressure switch, tank, & air chuck
Aftermarket fuel tank, 37 gallons. Option to add additional 52 gallon tank in factory location
Heavy duty skid plates
Exterior sprayed in Raptorliner tinted ceramic grey
Box:
Phenix CCV-108 steel crew carrier designed for forest service
R14 insulated walls and ceiling
Spring plate mounted
Passthrough boot to cab
10 exterior LED lights with lighting controller
6 interior LED lights
6 locking exterior compartments, LED lit from lighting controller
21ft total vehicle length, 9 ft height, slightly over 5ft interior height
Camper:
Full camper conversion designed for 3 people, 1 week+ off grid, three season capable
30 gallon fresh water tank, electric pump, tank level transducer, interior/exterior sinks, outdoor shower, instant propane hot water heater, small grey water tank
300 Amp/Hr AGM battery bank, auto-relay to engine batteries and alternator, 250 Watt solar panel system, 2000W AC inverter, Renology battery monitor
Diesel heater, Dometic vent fan with thermostat
Outdoor kitchen with propane stove, indoor induction cooktop
Sleeps three: trifold sofa makes full size bed, electric cable actuated bunk bed makes twin+ size bed.
ICECO 12V fridge
12V television with built in DVD
Three drawer dresser with upper locking compartment
Laveo dry flush toilet (no black tank or sewage dumping)
Aluminum scissor stairs
Mounted toolbox in exterior compartment
Overview:
The Ram 5500 adventure truck started as a BLM Silver State Hot Shots Crew Carrier in Nevada and was eventually sold at government auction. When we acquired it, it was still a crew carrier. The truck box has now been converted into a camper with water, power, & heat to last at least a week without needing provisions. The box interior offers a secure, comfy and insulated space while the exterior compartments are utilized for outdoor utility. Two of the compartments work as the main outdoor kitchen and sink setup, while the rest act as infrastructure or storage. The smaller box and chassis size means the length is only 21 ft and 9 ft tall, which is great for exploring more remote areas. The truck is very solid (drivetrain and box build) and has proven itself very capable in the backcountry. We’ve taken the truck through 7 states, multiple mountain passes, dozens of national parks and monuments, and spent 50+ overnighters exploring many remote areas. This truck is a great fit for a couple or small family who like to explore the unbeaten path and settle down for a while.
Additional info:
Tires (and truck) ride smooth on the highway.
Hwy speed 65-75 MPH, tires are speed rated at 68 MPH. TPMS system installed to monitor tire PSI & temperature
All maintenance up to date. All fluids & filters have been changed since ownership. Replaced tie rod, steering box, thermostat, coolant hoses, serpentine belt, both batteries, entire DPF system. Service documentation available where applicable
Registration has not been converted to RV. If desired, truck does qualify for inspection in Arizona to be registered as an RV
Emission compliant. Passed AZ emissions June 2022
OverlandFT
More pictures
RAM5500 CAMPERTHING
OG Portal Member #183
I dig this! GLWS
Question... How on earth did you fit a belt driven compressor on the 6.7? I've been researching this for awhile with no luck.
Any pics of it??
Thanks
MTAA
So couch is a sleeper sofa, correct? Looks like it can not be removed from the rig without deconstructing the sofa?
Is there a trailer hitch in the rear? If so weight capacity?
OverlandFT
I dig this! GLWS
Any pics of it??
Thanks
It's a Sanden style A/C compressor that was mounted on the driver's side using a special bracket and pulley. This was done as part of the up fit for the box HVAC. Once I deleted the box HVAC, I replumbed the compressor line to pull air from the filtered air intake and added a line oiler & collector to lube the compressor. Lastly, I wired the clutch to one of the RAM aux switches. Makes for a pretty high volume air compressor! Fills up tires and paddle boards, but by far the best use is attaching a hose and spray nozzle to blow out dirt from the camper!
I just have one picture of the compressor. Doesn't show the full bracket, but should give you an idea on the location. Driver side, above the steering pump.
OverlandFT
Yes, the sofa is a sleeper and makes a full size bed. We use a 3" memory foam topper and it's comfortable. It's a been a while, but I think I removed one armrest to fit it in the camper (bolt installed). So, yes.
Currently no trailer hitch is installed.
RAM5500 CAMPERTHING
Thanks for the reply. I’d love to add One to mine.
I’ve had York belt driven compressors on several of my builds and love them.
Great work! GLWS
2014 jeep jk
Hello,
Can you post any undercarriage or frame pictures? Also a close up of the rear frame where a tow hitch would possible mount? And pictures of the engine bay.
thanks
Henrybrowne
