FOR SALE 2003 Unimog U500 GXV Conversion $400,000
GaryCatlin
2003 Unimog U500 with 2015 GXV Safari Expedition vehicle build. Located in Seattle Washington. Full AV system including Cellular connection, Marantz 2 zone Receiver (indoor/outdoor), mobile KVH Direct TV, Apple TV, Sirius XM, PC and BGAN Emergency Sat system. Queen bed, Dinette, Induction cooktop, Drawer Fridge/Freezer, Wet bath, 2 rooftop mounted AC/Heat. Diesel power hot water/heater system. Lithium Mastervolt system with Solar panel and Onan 8000 Diesel Generator. Cab features : Heated leather air ride seats, Backup camera, Alpine stereo with Aux, Bluetooth. Red dot rooftop ac. Motorola 2 way radio. The truck is equipped with 2 16,000lb hydraulic winches with synthetic winch rope that can be run in tandem from the cab. 170 Gallon total Fuel capacity with built in transfer pump between tanks. 20" 2 piece wheels. Mercedes 6cyl Diesel motor serviceable by Freightliner.
The only known problem is that the turn signal does not always cancel on one side.
UTfromSF
Awesome rig, GLWS.
Can you provide some details about transmission/gearing/speed and also the dimensions of the habitat (including stand-up height inside)? Thanks much
  • Like
Reactions: zip
GaryCatlin
Awesome rig, GLWS.
I will try to find a copy of the layout.
it is a GXV safari extreme and the layout is on the website. I am 6' and there is plenty of headroom I would guess 7' but I would have to measure to be sure.
The truck is an Manual Transmission with electronic shifting. So you have a clutch pedal but you select gears sequentially through the electronic shifter.
The truck is equiped with the "fast Axles" which means it will go 69mph.
PNWav
