My wife and I were squeezing an overlander build in so we could travel more, off the beaten path as it were.
Unfortunately my wifes family is the history of diabetes, and, well, she passed away due to complications of Diabetes on July 19th.
I am scrapping the 2 person design for the camper shell overlander, and I am going to continue the build and go on with our travel plans as I feel now I MUST do them more now than at any point ever before, including going fishing with her hot pink sparkly collapsible fishing pole...
So as a bucket list I am proceeding with the changed build, so here goes.
Photos pending. Sorry I can't find them at the moment, but I wanted to start the build thread for my '04 F150 XLT Supercab 4x4 5.4L 3V.
So here is the status so far.
Truck.
2004 F150 XLT Supercab 4x4 5.4L 3V. Engine rebuild in progress. All upgraded hardware with TSB fixes on the VCT system, and an upgraded Melling Hi Flow oil pump. 9.75" rear with 3.55 gears.
Go Rhino Brush Guard / winch bumper.
Engo E9000 (largest allowable with the winch bumper) 9K winch.
Rancho Quicklift 2.5" fitted with Moog HD coils, RS9000 shocks.
Moog Problem Solver upper and lower ball joints, tie rod ends.
PowerStop slotted / dimpled rotors and Ceramic pads.
Explorer ProComp Stainless Steel off road lights. These predate LEDs.
AirRAID cold air intake
SCT XCal2.
Magnaflow high flow cats
Pro Comp 1089 17x9 rims x5.
35x12.50/17 Hercules Trail Digger MT x5. Front fenders clearances via bead trim and fold, plastics trimming for clearance.
Duracell AGM battery
Realistic TRC-465 AM/SSB with 102" whip and 6" SS spring.
Bed Rug.
Unknown MFG Fender flares with 1.5" added tire coverage.
Towing harness, and Ford towing package tranny cooler.
Line of Fire LED accessory brake / turn / tail lights.
Haul Master hitch hauler.
Completing the truck itself build I originally wanted, I am wanting to swap the Hercules tires, all 5, out for a fresh set of BFG All Terrain TAs, and I am dropping size down from 35x12.50/17 back to 285/70R17 which I had on my first set of tires on this truck. It worked well and looked good with no rubbing.
I want to upgrade the diffs as I believe ARB now offers air lockers for the 10.25" rear and 8.8" IFS front, along with a compressor and front / rear selector switches / valves etc... Swap over to 3.73 gearing, or at most, 4.11, towing is good, highway mileage would be better.
Swap out the OE exhaust for a Summit racing 3" cat back system, cut in and graft a 2.5x2.5x3" Y pipe on the cats, and add a reasonable Magnaflow muffler. I am looking for added power, especially on the low end, not noise.
IF possible, upgrade the Pro Comp lights with LED elements just to be different, add LED cowl lights, roof rack lights, and reverse lights grafted into rear bumper.
Android auto replacement stereo system with reverse camera monitor.
Reverse cameras, Probably a tailgate handle replacement cam. This would be able to assist in trailer hitching.
I thought I had a Leer 122 available, but we were mistaken. It was for a Silverado, not an F150 and things just didn't line up...
Since it is just me, I am going to go with a Tri Fold memory foam mattress in Twin size to fit easly between the wheel wells, and fold up to a day use table. I will instead of building a bed platform, build side cabinets for storage / water / power systems
As the Craptor builder showed, using an E350 battery box, or two, mount house batteries under the truck between frame rail, and side of the bed wall...
I will use or fabricate one of those donuts that you can use to seal the back of the cab to the front of the cap and replace the OE window with a large opening slider. I want my Dog to be able to go between the cab and the bed...
Build, or add lockable compartment to hitch haul to add spare gas cans, 20lb propane cylinder, Port o Potty in transit, AND 2KW inverter generator.
Determine best mounting / stowage for recovery gear, including 2 sets of MaxxTraxx clones. One with hi lift pads, one without. Logging chain, recovery strap, D shackles, tree strap, snatch blocks etc... Right now everything BUT the MaxxTraxx clones fits under the back seat, along with plenty of trail repair tools.
I am looking at an Iceco 60qt 12v fridge, good reviews, great size, and more than enough capacity for just me but includes room to grow for a friend. This will go in the cab behind the front seats.
I know I need to be super careful with weights, and as such everything will get scrutinized 3 to 4 times before it goes in, or on...
Hopefully I don't build myself into a corner where I HAVE to upgrade to a heavy duty truck...
The stage I am in right now, the truck itself is getting picked up in about a week to go to the shop. The old 5.4 3V is getting swapped out for a new crate motor with all the TSBs applied, tranny will be pulled and all hoses etc... are to be replaced / fluids flushed and replaced. New exhaust will be installed at the time of the new engine. Probably throw new master cylinder, brake lines, and calipers at that time too...
So. What do I need?
Well if anyone has or knows of a Leer 122 for an '04-08 F150 6.5ft standard bed, at a reasonable price somewhat closeish to Texas, PLEASE let me know! I will also seriously consider a hi top aluminum contractors cap. I am not going for style, I am going for dry enclosed space and insuation ability...
Truck.
SCT XCal2.
Bed Rug.
So. What do I need?
