Roaming Lost: 2022 RAM 3500
Regcabguy
Oil eater.
No issues. They do what they’re suppose to but I was running them at 90psi max ok airbags is 100 psi. Still had sag. So definitely a bandaid in my case.
Bags at 90 psi are like riding on bumpstops.
What's your rear axle weight? Nice setup and the Torklift steps are the best.
Regcabguy
Oil eater.
I've found airbags are very progressive. So, they ramp up the spring rate quickly, with very little travel. Just ok on the street, but still harsh off-pavement. There are long travel bags that would be better.
I've thought of using big-port bags that you can hook up to a remote air tank to make them less progressive with the increased volume. Maybe install a valve or an orifice to change the rate.
I've had Carli bags since their inception along with their mini paks. The XXD Deavers look nice. I have a rear axle load of 4000# with my 2200# Northstar camper.
roaminglost
Camper/Starlink got a significant upgrade today.
I always had to fuss with the cables and crack a window or the hatch, which allowed bugs or whatever In. Plus, having the cabling run through the camper was a tad annoying. So today, I chopped It up and ran the cable to a waterproof connection on the back of the camper.
I also wrapped the cable In 1/4 PET so its a tad bit more durable.
Here Is a parts list:
www.shorturl.at/djrv2 (waiting on this part, but it'll be the pass-through from the inside of the camper to the storage cabinet.
www.shorturl.at/exILM
www.shorturl.at/hUXZ2
www.shorturl.at/gvLZ3
www.shorturl.at/qHLPQ
www.shorturl.at/cqxyR
www.shorturl.at/ptyN0
V45W_Proto2.5
