MLu
I've been looking for the next step up from sleeping in the back of my Discovery II, but I think I may have skipped a few steps on the way...
I bought a 2014/15 dual cab (906.233) 4x4 flatbed Mercedes-Benz Sprinter. The idea is to build it up to be a four-person, four-season, four-wheel drive overland camper, used mainly in Northern Europe. Eventually adding on trips to Russian Karelia and the Kola peninsula, more of Europe, at some point perhaps Northern Africa and the pipe dream always being Mongolia and the 'stans. Compared to the disco, it's certainly no offroader, but driving it around some snowy fields and forest roads makes me fairly confident it'll take me where I need it to go, despite no low range. At least it's leaps and bounds ahead of my dad's RWD Sprinter ambulance-conversion when it comes to clearance, traction and angles.
Aiming at having an onboard hot shower, separating toilet, queen size(ish) bed plus dinette that turns into more sleeping, induction cooking. Looking to keep it electric and diesel only, no gas. No pass-through. All fluids indoors. All this on a 3665mm wheelbase with a crew cab and about 1100kg to work with.
At the time of writing, I'm fiddling with figuring out the layout of the camper so I can start getting quotes for composite panels (anyone know a good supplier in the Helsinki region, hit me up...). I was hoping to do it without an above-cab sleeping alcove, but that's probably not going to happen, so I'm likely to end up in the 3,5 meter height range, unfortunately. The current flatbed is 276cm, I'm looking at having the box end up at about 350cm with the last 50cm over a 45 degree angle, plus probably an alcove over the cab.
First question: do I REALLY need to engineer a three-point or other torsion-free subframe solution?
Between the cab (which I believe is fairly rigidly attached to the frame, please correct me if I'm wrong, but looking a picture I took it seems to be literally welded to the frame) and the rear axle is about 130cm, the total frame behind the cab is something like 240cm. The flatbed that's on it has what looks like a seriously stout subframe solidly bolted to the frame. In addition, the Mercedes Body/Equipment mounting directives (aka Bodybuilder's guide) clearly states that self-supporting bodies can be attached directly to the frame without a subframe, and that ALL assemblies must be attached to all factory attachment points on the frame. Best case scenario: removing the flatbed and subframe and attaching directly to the frame would save me at least 20cm of space; second best scenario: utilizing the existing subframe would save me from designing and building a frame and simplify the construction significantly by not having to make and work around wheel wells.
