Get build sheet with VIN
meecect
I think i'm going to replace the rear axle on my quigley 2000 e350. Quigley says my rear axle is the factory oem and that I should be able to get the specs from Ford with my VIN.
Does anyone have a link or service that I can use to get my build sheet from the VIN? There is no tag on the diff anymore and it is too rusted to really see any details on it.
thanks,
Lmg
How can I get a Build Sheet for my Ford?
Marti Auto Works
9966A5AF-5D12-4C8D-AA9F-6061DBD0BA88
is the licensee to Ford's production database and provides information about any Ford Motor Company vehicles made in the United States or Canada from 1967-2017. Visit the Marti Auto Works website to determine which build sheet is right for you.
Build sheets, or Marti Reports, provide the complete factory options list and door data plate info for Ford Motor Company vehicles. They provide details such as engine size and transmission, paint codes, production date, axle code and ratio, and more.
Notes:
  • Marti Reports are delivered as a PDF by email. If you require a hard copy to be mailed to you, select the Print Service option.
  • Visit the Ford Show Parts website for 2007 and newer model duplicate window stickers
vintageracer
To Infinity and Beyond!
Stop by your local Ford dealer parts counter with the last 8 of the VIN.
They can tell you everything you want to know.
Nbalbo2010
thanks,
Do you happen to have a build sheet for your van from quigley you could send me? I’ve got a set of parts from an ‘02 I want to to swap over to a 2000 e350 van terra, but trying to compare build sheets to make sure they are compatible. Thanks!
oskarf150
