The single biggest headache of this project thus far has been the brake lines. I saved them until last for good reason. The front soft lines meet the hard lines at the frame in a sandwich. Its the worst design ever. (Ive seen other Chevy trucks of the same era with mounts that hang below the frame which would have been nice.) Access is horrendous, parts are delicate, design is terrible, even on a rust free Arizona vehicle rust/corrosion does its thing. I had to heat the fittings so much the hard line was surely liquid metal at some point. I chose the path of continually heating/cooling/heating in hopes the threads would loosen but the line would be strong enough to stay put. Thankfully this was the case and eventually I got them both undone. As soon as I removed the soft lines and calipers I noticed that both calipers were in crap condition so I got new ones for a whopping $29 a piece ha!
The stock rubber line was nearly taught at the new ride height so there was no option but to replace with extended lines. The union of the hard and soft lines is a hole cut in the frame thats round with flat sides. There is a notch for a horseshoe clip on the inside of the frame where its literally impossible to get your hand/arm/tool of any kind to actually push the clip into place. There is a hex built into the soft line on the outside of the frame and a hex nut on the inside of the frame to bolt it all in place. Then the hard line fitting threads into the soft line fitting that comes through the frame It's all just unnecessarily complicated and nearly impossible to reach. In the end I skipped the horseshoe clip because there was just no way to push it into place. It doesnt help working on your back either, a lift would be nice for this. Thankfully everything went tight just synching down the hex nut.
Stock line going into the frame.
ORD line going into the frame.
ORD line coming through the inside of the frame. I had to leave both sides of the line loose to line up the fittings and get the threads started. Then tighten everything after the fact. Even though this made it more painstaking to finish the install, cross threading in this situation would open up pandoras box of redoing all the hard lines.
And thats just the front!!!!!!
I expected to rear to be easier. Its only a single soft line from the frame to the axle so its gotta be half the time/work/headache, right? WRONG. I couldnt get the mounting block undone from the bracket where it bolts to the diff, problem number one. Put some heat on it, blow the rubber line off the fittings and douse myself in boiling brake fluid, great. Eventually enough heat gets the bolt out of the mounting block. Ok lets move on to the upper soft line mount. Wont budge, great, problem number two. Fresh off the heals of blowing up the rubber line with heat, Im now working right at the gas tank and gas lines where the hard and soft lines meet and this old girl smells like gas all the time. After a couple minutes carefully using the torch I decide this is not a great idea. Especially with a 1/4 tank of gas, lots of fumes that can go boom. So I start working my way up the frame, undoing the hard line up to the union halfway up so I can work the hard line loose and try to remove it to separate the lines outside the truck. Not gonna happen. All the various bends in the line, frame, brackets in the way etc. are not going to allow the hard line to be removed from the frame without destroying it. More on this later. Eventually I get the soft/hard line junction wiggled far enough away from the gas tank that Im OK trying heat on it again and it works, sweet, now Im making some progress. Install the new soft line and were just about ready to bleed the brakes and drive the truck again. All I need to do is loosen the bleed screws at the drums...just loosen em up and call in wifey to push on the brake pedal for a few minutes...just loosen em up and we're home free.
WRONG.
Problem number three. Passenger side bleed screw wont come loose, heat it up seemingly forever, wont come loose. Ok fine undo the hard line going into the cylinder, immediately strip the fitting beyond recognition, using flare nut wrenches. Try all the sizes of vice grip that Ive got and nothing. Ok guess Ill be replacing the passenger side hard line, Ill just buy a new one tomorrow. Nope, nobody in town has hard lines nor can anyone make them. So my options are make my own or buy new ones from LMC or some other place online and wait. I decide to order the two rear axle hard lines, foregoing ordering all of the hardlines. Im now worried that I should have ordered them all but thankfully it worked out in the end. Im still pretty tempted to redo all the hard lines on the truck for piece of mind.
Here is a picture of just how close the upper soft brake line mount is to the gas tank. About 2 inches. Also worth noting, in the top left corner of this picture is a fuel line, a rubber line with a crappy ladder clamp, about 4 inches from where I was trying to use a torch to loosen the fitting.
