2018 Fuso FG4X4 camper (Canada) SOLD!
lvivier
SOLD!
This has been my dream vehicle, but now it can be yours!
2018 Mitsubishi Fuso FG4X4 was bought new in 2019, and has a lightweight insulated fibreglass/foam camper body by Total Composites. The articulating subframe was engineered and installed by Intercontinental Truck Body in Vancouver.
The camper interior was completed by myself and is intended for full time living. Interior wall partitions are fibreglass honeycomb panels and the CNC cut cabinetry is 18mm Joubert Poply light weight plywood. Galley cabinet fronts are 18mm black walnut veneer plywood. Head cabinet fronts are 18mm teak marine plywood.
Build is 95% complete, some items to be completed prior to sale are noted below.
Located in Victoria, BC.
Asking $150,000 CAD.
Equipment List
  • 2018 Mitsubishi Fuso FG 4x4
  • 3.0L I4 turbo diesel
  • DUONIC 6-speed dual clutch automatic transmission
  • Factory limited slip rear differential
  • Exhaust brake
  • Drivetrain warranty until April 2024
  • 3.41m (134.4") wheelbase
  • Overall dimensions: 6.4m x 3.4m x 2.12m (21' x 11'2" x 7')
  • Purchased new, only 10,000 km on odometer
  • Manuals, service records, original sale documentation
  • Service manual (6,000 pp PDF) included
  • 3M vinyl wrapped cab (factory white paint)
  • Cab thermal and acoustic insulation
  • Sony head unit with Apple CarPlay and backup camera
  • JVC speakers
  • Accessory 8x switch panel
  • Rough Country SAE/DOT approved road legal fog lights
  • 17” super single wheels from Fuso Offroad including spare wheel (no tire)
  • Hankook Dynapro M/T 37x12.5R17 tires
  • Wide fender flares from Fuso Offroad
  • 15’ custom camper box from Total Composites
    • Fibreglass foam composite panel construction
    • 4.68m x 2.12m x 1.12m
    • 45 degree departure angle
    • Tern Overland insulated door
    • 4 Tern Overland double pane windows (+ one more for bunk area, to be installed)
    • 2 Tern Overland double pane, power sunroofs with integrated LED lighting
    • Maxxfan ventilation fan with remote control
    • 2 small and one very large cargo access door
    • Locking fresh water fill door (to be installed)
    • 2 large ROAD Overland cargo boxes with locking doors
    • ROAD Overland pull-out entry porch and stairs
    • All locking doors/hatches are key matched
  • Powdercoated steel subframe by Intercontinental Truck Body
    • Subframe has integrated, insulated water tanks for lowest centre of mass
    • Transport Canada door sticker
    • 2 hitches for cargo accessory like bike/moto rack, spare tire rack etc. on back wall
  • Camper electrical system and electronics:
    • Renogy 340 Ah LiFePO4 house battery bank, room to expand to 680 Ah
    • Renogy 2000W pure sine wave inverter
    • Renogy 50A MPPT/DC-DC charger: charges from solar panels/alternator, and trickle charges starter battery
    • Renogy 20A shore charger rated for 100-240 VAC, 50/60Hz (not installed)
    • 350W solar panels, loads of room on the roof for more
    • Simarine Pico smart monitoring system with colour display
      • Current shunt and voltmeter for house battery bank status
      • Voltmeter for starter battery status
      • 2x thermostats
      • 2x water tank level senders
    • 2.4Ghz/5Ghz dual band WiFi router and 4G LTE modem
    • Dimmable and colour temperature selectable LED ambient and task lighting with wireless controllers
    • 2 dimmable and touch-sensitive reading lights (+ one more for bunk area, not installed)
  • Camper plumbing:
    • 220L fresh tank
    • 90L grey tank
    • 12L hot water boiler
    • Drinking water filtration with its own faucet in the kitchen
  • Camper interior:
    • Oak look vinyl flooring
    • Mix of matte white and natural wood cabinetry
    • Planar diesel heater (draws from primary fuel tank, consumes 100 - 250 ml/hr)
  • Kitchen:
    • Isotherm Freeline 115L 12V compressor fridge/freezer (spare compressor controller included)
    • Single burner induction cooktop
    • Panasonic combination microwave and convection oven (you can really bake off grid in this oven!)
    • Residential faucet with integrated pull-out sprayer
    • Grain-matched black walnut veneer cabinet fronts
    • Gloss white/mica flake epoxy countertop
  • Head:
    • CompoostToilets composting toilet, urine plumbed to grey tank
    • Sink with pull out shower head faucet (regular faucet installed in photos, to be installed)
    • Vanity mirror/medicine cabinet
    • Marine ply teak cabinet fronts
    • Medicine cabinet door fronts are Lexan mirrors (to be re-installed)
    • Lots of head room with the sunroof
  • Dinette/bed:
    • U-shaped dinette makes up into king sized bed (6’8” by 6’)
    • Custom 5” memory foam cushions/mattress with zippered Sailrite Sunbrella fabric covers
    • Stable heavy-duty yacht style centre table leg with gas lift
    • Tri-fold white oak veneer dining table (table "folded" surface may need refinished)
  • Bunk:
    • Elevated bunk bed for a child (IKEA toddler bed size)
    • Hanging locker (can be removed to extend bunk to adult length)
    • Storage cabinets below
    • Plumbing roughed in for a Daewoo Mini Drum laundry washing machine
    • The bunk area cabinetry is not 100% finished, missing cabinet floor and shelves
    • The bunk needs a lee cloth/retention and a ladder
  • Accessories:
    • Dragon Fly Tarps custom sized Haku tarp
    • 13’ tall extending ladder for roof access
    • Really big torque wrench for torquing wheel nuts to 398 ft/lb
    • Really big recovery gear: kinetic, tow strap, shackles, pulleys
    • Powerbuilt 3-ton jack/jack stand
    • 20V cordless impact driver for loosening wheel nuts
    • Impact socket and extension bar for same
    • Viair 450H air compressor (not installed)
    • ABC fire extinguisher
    • Cordless hand vacuum cleaner
    • Spare fuses
Outstanding Items TBD
  • ROAD Overland roof rack to be installed on cab
  • Head doorway to be finished and door to be installed (frameless frosted Lexan door)
  • Water fill door to be installed & connected to fresh tank
  • Bunk window to be installed
  • Head pull-out shower faucet to be installed, or
  • wall-mounted shower head to be installed
  • Daewoo Mini Drum laundry machine to be installed (contact me if you want this!)
DirtWhiskey
Western Dirt Rat
Wow. What a truck. And an absolutely SMOKING deal for somebody. Best of luck! Anybody know if this could be legally imported to the USA?
nyyankees588
Wow... That is a beauty. As others have said, this is an amazing rig for the USD price... Some 4x4 sprinters are selling for more...
Sent from my Pixel 3 using Tapatalk
SOLD!
Equipment List
  • Exhaust brake
  • JVC speakers
      • 2x thermostats
  • Camper plumbing:
    • 220L fresh tank
    • 90L grey tank
  • Camper interior:
  • Kitchen:
  • Head:
  • Dinette/bed:
  • Bunk:
  • Accessories:
    • Spare fuses
Amazing rig! I missed out!
DFWSFO
