Dometic 65 Dual Zone - San Diego
blupaddler
Conspirator
DOMETIC 65DZ
Dual zone fridge/Freezer
Dual zone allows both fridge section and freezer section. Removable divider and you can use it as a stand alone fridge or freezer.
Ac/dc or 12volt usage for your car
Has internal battery cutoff for 12v use.
Comes with AC/DC plug and 12v cigarette lighter plug for vehicle.
Also have the insulated cover which helps it run more efficiently.
From Dometic:
The Dometic CFX 65DZ was engineered with the most adventurous traveler in mind. Featuring a weatherproof construction, and a hermetically sealed Waco compressor, the CFX 65DZ will perform in the most extreme conditions. The CFX 65DZ also features an easy to use soft touch digital control panel that utilizes the internal temperature sensor to ensure your food stays at the exact temperature you desire. With the ability to utilize multiple power sources the CFX 65DZ can be used in your car, RV, home, boat, or off the grid utilizing solar.
Specs:
*Capacity of 2.2. cu. Ft. / 53 l to fit up to 106 cans and upright 2 l soft drink bottles
*Dimensions: 22″ H x 28.5″ W x 17.9″ D
$700
Local pick up only
blupaddler
Conspirator
Pics
