For Sale : 2019 Transit HIGH ROOF Conversion [$45,000]
drifsonix
Hey Ya'll - I'm selling my van. It's a very basic build, perfect for someone looking to hit the road fast & make their own modifications as they learn what they like/dislike about the life. Or if you have your vision already but want to skip past the more tedious/foundational steps, this is the van for you. The walls, floor, ceiling, ventilation, solar rack etc are all taken care of.
She is a bit of a fixer-upper in the electrical department. The solar & other wiring is in place, but will need to be reconnected to a fresh generator/battery/fuse box. I used a Goal Zero & am happy to assist with installing yours or if you’d like me to take care of that in advance, we can discuss options there. Although doing it yourself is half the fun! The setup does include a combiner box, so you can easily switch the solar array from series to parallel to match your needs.
This is a great van & I cannot stress how awesome the high roof is. I've had people over 6" tall inside, standing up and comfortable. I used it primarily as a mobile studio for music, podcasts, creative work, so it's quite spacious & designed for company. If you wanted to make into more of a home, that would be no problem at all. I installed crossnuts throughout, so the entire inside is quite customizable without the need to drill into any metal. My furniture can be easily replaced with yours!
Below are some videos of the van/build as well as more info. Happy to answer any questions you may have about the van or life on the road in general!
CARFAX & original window sticker in the images. It says two owners because I transferred the title from GA to NH. You'll see the date overlaps with when I was having it serviced in CO.
Tour:
Conversion Timelapse:
Longer Technical Tour:
-69,269 miles
-Purchased with 39,400
-30k since was mostly highway
-Clean title, two owners
-6-Speed Automatic, 3.7L V6 engine
-GVWR 9,000LBS
-Original owner’s manual & quick reference guide
-Back up camera in center console
-Power windows/doors
-Lane assist
-Cruise control
-A/C
-Bluetooth & CD Player
All Service Records Retained
-Passed NH Inspection August 2022
-New rear brakes & battery July 2022
-Nokian WR C3 All Weather Tires
-No mechanical issues/accidents over ownership of van
-Regular oil changes
-Rear shocks recommended soon. Not dangerous, at some point you will notice them “go” and will need to replace
Conversion
-Scytek alarm system with mobile app, GPS tracking, engine disable features
-Six 100w Renogy Solar panels on roof
-Custom & adjustable rack
-ECO-WORTHY PV Combiner box
-Easily switch between series/parallel wiring. Turn power on/off for maintenance etc
-Maxxfan 7000k ceiling fan with remote control, 10 speeds (+ reverse) & thermostat control (set to the temp you want!)
-Ceiling & walls insulated with 3M Thinsulate SM600L Acoustic Thermal Automotive Insulation & Low-E SSR -Reflective Foam Core Insulation
-1/4in ply Birch walls & ceiling
-Floor insulated w/ Minicell foam insulation, OSB subfloor, Traffic Master Vinyl Tile Flooring
-Custom air intake installed behind passenger seat, allows for constant air flow & prevents vacuum/pressurization when fan at full power. Can be covered/closed in cooler weather
-Overhead storage cabinets
-Bench seats with storage beneath
-Adjustable table – Up, Down, 360 degrees from two swivel points (Lagun USA mount)
-End table/workbench
-Side & back door bug screens, magnetic closures
-8 LED puck lights in three zones with independent dimmers
-Crossnuts throughout, allowing for simple & repeated modifications without the need to drill into the van
drifsonix
Rest of CARFAX & remaining Window Sticker
Happy to answer any questions you may have!
Thanks
