lkadjflakjsf
The Truck
2017 Nissan Frontier SV 4x4 (crew cab / long bed) 78,500km
I purchased this truck @ 73,000km and have changed all fluids with high-quality full synthetic fluids except for the power steering.
The truck has a rebuilt title from relatively minor front-end damage. All repairs were professionally done, and certified by ICBC (Insurance Corporation of British Columbia). The truck has a 2.5-inch lift front and rear (details below) with Falken Wildpeak AT3W 265/70/16 tires. This truck was used for camping and mountain biking trips, e.g. no hardcore off-roading/rock crawling. Bike rack not included in price.
$60,000 CAD
Body
Asfir full aluminum skid plates (brand new) (https://www.asfir.com/skid-plate-set-591070b.html)
Coastal Offroad steel high clearance rear offroad bumper (https://www.coastaloffroad.com/product-page/2nd-gen-frontier-high-clearance-rear-bumper-kit/)
New SKF front hub bearings
Fumoto oil drain valve
Rear differential breather mod
LineX professional bed liner
Front Suspension
ARB Old Man Emu Nitrocharger Sport Strut - 90003
ARB MD Front Coil Spring Pair - 2607
1" Lift Top Plate Spacer
SPC adjustable and greasable upper control arms
Adjustable sway bar links
New lower control arms with greasable ball joints
Rear Suspension
Custom heavy-duty leaf pack
CJD adjustable extended shackles
Bilstein B8 5125 extended travel shocks
Extended bump stops
2.5-degree axle shims
Hiatus Camper
Hardwall popup camper (https://www.hiatuscampers.com/)
Custom fabricated to fit both Nissan Frontier AND Toyota Tacoma
Custom 80-inch sleeping bed length
MaxxAir powered fan
Side hatch access
LED dimmable interior roof lighting
My additions to the camper
Propex propane furnace (dry heat!) w/ 10lb propane cylinder and external aluminum door mount
CO/CO2/Propane 12VDC RV alarm/detector (suitable for high humidity environments)
Renogy 100ah self-heating lithium battery box with USB/Anderson connections
Renogy 30amp DCDC/MPPT on board charger with a portable 120w solar panel
1/2" plywood waterproof treated flooring with 1/2" rubber bed mat on top
Custom L-track mounts throughout the floor and bedsides
45L 12VDC fridge/freezer (Can also be run on AC with the adapter)
Front and rear dash camera/backup camera
2m x 2m ARB awning with 3 wall room - this can be mounted on the side or rear of the truck to make an extension.
Front and side ARB awning mounts
Rear-facing Rigid LED flood light
Thule roof rack crossbars
DeWalt TOUGHSYSTEM 2.0 Extra Large Tool Box with a set of winter rear tire chains, tire repair kit, and jumper cables.
$60,000 CAD
Body
Front Suspension
Rear Suspension
Extended bump stops
Hiatus Camper
MaxxAir powered fan
Side hatch access
