Isuzu NPR-HD 4x4 For sale $85k (Earth Cruiser Like)
iskipowder
The original Ridgerock expedition vehicle. Used for three years, been living in it full time for 6 months; I'm ready to build up another one and let this one go to a proud new owner.
2007 Isuzu NPR-HD 177" chassis
253k on the odometer but these trucks are redone. Motor and drivetrain around 100k.
Located near Telluride Colorado.
iskipowder
More outside pics
iskipowder
Interior pics
iskipowder
2007 Isuzu NPR-HD 177" chassis Isuzu NPR-HD 4x4 For sale $125k
The original Ridgerock expedition vehicle. https://www.ridgerockexpedition.com/
253k on the odometer but these trucks are redone. 6.0 Engine and drivetrain around 100k. Box is 8'wide x 20' long x 9' tall. It's a stock Morgan body. The walls and ceiling were filled with spray foam insulation and a vapor barrier. 1.5 inches on the walls and 2.5 on the ceiling so it's well insulated and very sound proof.
1- Double Bed
1- Twin Bed
1- Double Futon
1- 24" TV
1- 8kw Deisel Heater
1- Electric Heater
1- Cubic Grizzly Wood Stove
1- Camp chef 2 burner propane stove
1- 12v RV Exhaust stove fan
1- 120v Dorm Fridge
1- Maxx Air Fan Deluxe
1- On demand propane Water Heater
1- Dometic Masterfluch 8900 Toilet w/ macerator and bidet
1- Shower
1- Bar sink
1- 56 gallon on board fresh water tank
1- 45 gallon black water
1- 35 gallon gray water
1- On board water pump and expansion tank
1- Shore water and waste hookup
1- Shorepower hookup 50 amp
2- 100w solar panels
1- Renogy Rover 40amp MPPT Solar charge controller
1- Renogy dc-dc 40 amp charger
1- Renogy 2000w inverter
1- 120v-12v charger
1- AC/DC fuse panel
8- Led interior lights
2- Exterior motion lights
1- Exterior flood/spot light
1-custom front bumper with steps
1- 16 ton warn winch with synthetic cable
4x4 has a high and low range manual hubs.
2- Dana 60 axles with limited slip differentials
Jack Mac
Expedition Portal Staff Member
Staff member
Hey, does the truck have air conditioning/cruiser control? Guessing no lockers? Thanks, Jack
iskipowder
Hello, Jack, yes the "truck cab" has AC and cruise control. You are correct, there are no differential lockers but they are limited slip. The front hubs are mechanically switched to lock in 4 wheel drive.
iskipowder
Whats the box construction?
Hello, the box is 8'wide x 20' long x 9' tall. It's a stock Morgan body. The walls and ceiling were filled with spray foam insulation and a vapor barrier. 1.5 inches on the walls and 2.5 on the ceiling so it's well insulated and very sound proof.
DanoWall
