2004 Ford F-250 V10- 6 speed-4wd // Camper Shack TRUCK is SOLD Camper still available
UHAULER
Update- The truck is Sold. The camper alone is $4,000
Nevada City , California
Sean 530-315-5195
The Camper
Built earlier this year. Base frame is 1" sq. tube with framework going down to the front and back of the bed floor to evenly distribute the weight.
The camper is framed with 1.5"x2.5" wood studs. The skin is .320 ac plywood. It is sealed with 2 coats marine grade epoxy resin.
Painted with 2 coats oil based enamel.
1.5" rigid insulation walls and ceiling.
48" wide door.
Bed frames are 1" sq. tube and easily removable, not bolted down.
Mattresses are high quality 5" foam and heavy duty covers from TruckMattress in Oregon. The upper mattress is 30x74. The lower is 34x80.
Interior dimensions are approx. 74" wide, 74" high,80" long with 48" cabover storage.
Now for the question why are you selling ? Right now i'm just gonna lay low, close to home and enjoy riding my motorcycles. I think if I was to get something else, it would probably be something less capable off road with more amenities, something like a 14' box van or small class C sized.
I also have a small 6' wide ,8' long trailer I would sell for $4,000.
It's a great little trailer to bring the toys with you.
UHAULER
UPDATE- The truck is pending sale. The camper alone is $4,000
This is a perfect fit on a Ford f250-f350 shortbed, I believe 1999-2016 are the same.
V45W_Proto2.5
