SALE PENDING: 2021 KIMBO SERIES 6 CAMPER No. 98
RVN_633
2021 KIMBO 6 SERIES CAMPER #98 BUILT IN BELLINGHAM, WA
Purchased new 21 May 21 (still in excellent condition)
Currently in SIERRA VISTA, AZ - Asking $27, 500.00 OBO
Ultralight durable frameless aluminum construction 950 LBS DRY WEIGHT
Fits in standard 6’ truck bed (w/tailgate closed)
  • Stainless steel marine sink with hand pump faucet
  • Includes aftermarket rechargeable USB faucet as option
  • 2.5 gallon under counter multi-use water tank for refilling hot or cold water
  • Shower module/under seat storage area
  • Ceiling mounted shower curtain
  • Water proof floor pan with gray draining doubles as storage area when not in use
  • Includes aftermarket rechargeable USB shower head
  • Heating
    • Dickinson high efficiency marine Fireplace LP
    • Uses 30 lb. propane tank (included/filled)
  • Power
    • 100-watt Rooftop mounted solar panel
    • Room to install 2ND Panel
    • Charges included GOAL ZERO YETI 500X POWER SYSTEM
    • Powers variable MAXX FAN for drawing in/pulling out
    • LED interior lighting (dimmable) with remote
    • Furnace fan
    • Charges your electronic via USB/USB-C (60w and 18w ports)
  • External plug for connecting to shore power
    • Powers above listed items plus charges GOAL ZERO
  • Full Size bed (over cab) east to west facing
  • Nine wall mounted storage baskets
  • Closet area for hanging/storing clothes
  • “Mud room” entry for wet/muddy boots/gear
  • Three multi-position windows with blackout shades and bug screens
  • Two seating areas with movable tables
FOR MORE DETAILS SEE KIMBOLIVING.COM OR KIMBOLIVING ON INSTAGRAM AND YOUTUBE
OR MESSAGE ME FOR BROCHURE WITH DIMENSIONS.
THINGS TO CONSIDER
  • Table for lagun mount is simple but effective birchwood plywood, may want to replace with something nicer.
  • This unit is designed for off-grid use in mind. There is no plumbing or holding tanks, therefore no winterization is required when storing.
  • Depending on vehicle model, may need to use (included) platform to ensure proper clearance of cab, especially rear roof mounted antenna. Will also include rubber mat to help with any slipping.
  • Uses four heavy duty 5k lb. cargo straps to secure unit to truck bed tie downs.
Front_right side.jpegLeft side.jpegKitchen.jpeg Bedroom.jpegWork area.jpegRelax area.jpeg
RVN_633
I've attached the original brochure Kimbo sent listing the dimensions and price breakdown. I also included the invoice for my unit, which includes everything minus the actual fridge which I removed due to poor performance.
  • Kimbo 6.pdf
  • Kimbo Invioce.pdf
Casey4467
  • Heating
  • Power
    • Furnace fan
THINGS TO CONSIDER
View attachment 760353View attachment 760354View attachment 760355 View attachment 760356View attachment 760357View attachment 760358
Is your Kimbo still available?
Casey4467
  • Heating
  • Power
    • Furnace fan
THINGS TO CONSIDER
dhuss
