**BACK UP FOR SALE** 2006 Ford E350 Super Duty Bullet Proofed 6.0 Diesel w/ Stahl Service Body & CCV Poptop $95k obo
KDB
For Sale is a bullet proofed 2006 Superduty Ford e350 6.0 Diesel with Stahl Service body and custom fitted Colorado Camper Van Poptop. This one of a kind build that took over two years to complete by a compilation of some of the best conversion upfitters and aftermarket suppliers in the industry: including Agile Offroad, Aluminess, Ujoint, Colorado Camper Van, Adventure Bravely, Devil Mountain Diesel, Ruhne Racing, etc. The build thread can be viewed on sportsmobileforum.com 6.0 Service Body thread where it has garnered many tens of thousands of views and follows. A detailed walk through video link is posted below. The vehicle currently has around 131k miles. There’s approximately 20k miles since the conversion including all mods listed here. This rig can easily be stood up in with or without the top deployed making for a very comfortable and highly capable offroad vehicle designed for extensive overlanding and off grid use. Every detail and component is securely fastened and designed for heavy off road application. There are many redundancies built into the vehicle to avoid any compromising backcountry situations and with an ARB rear air locker there's few places you can't go. There’s an abundance of exterior storage creating for a very open and spacious interior for two or three. Can sleep 4-5. Every detail has been gone through. Not a single bushing or gasket that hasn’t been replaced. This is not a home build. Everything was professionally designed and installed.
The Bad: New tires will eventally be needed. About 30% left. New brake pads will be needed. About 20% left.
I have around $150k in receipts. Asking $115K. I can be reached at kristfrdb@gmail.com. Thanks for looking! Please click the link to see a detailed video walkthrough of the vehicle:
Engine & Mechanical
New:
  • Injectors and o-rings
  • Injector nipple set
  • Injection control pressure sensor
  • Bullet Proof 6 Phase Fuel injection module (FICM) w/ programming
  • Blue Spring Fuel Pressure Regulator kit
  • Oil rail stub pipes
  • Oil Cooler kit
  • Coolant filter kit
  • Bulletproof 6.0 Square EGR cooler
  • ARP head stud kit
  • Cylinder Head gasket
  • Machined Cylinders
  • Tappet Valve
  • Electric shift motor
  • Dynamat sound proofing to engine compartment
  • EDGE CTS3 Insight and EGT Probe Engine and diagnostics monitor
  • Oversized aluminum radiator w/ new upper and lower hoses.
  • Billet water pump assembly
  • High pressure oil pump/injection pressure regulator/ injection pressure sensor
  • High pressure oil pump T fitting
  • Turbo charger
  • Glow plugs
  • Snow plow alternator (HIGH output)
  • Serpentine Belt & Belt tensioner
  • Starter & Assembly
  • Agile offroad TTB 4x4 conversion
  • Tie Rod kit
  • Custom Tuned Fox 2.0 and Coil overs
  • Reman transfer case
  • Electric transfer case shift motor
  • AOR electric shift on the fly system
  • Dana 60 rear axle
  • ARB rear air locker
  • Redhead steering gearbox and drag link
  • Block heater (self powered through the vehicle power bank)
  • Rear sway bar
  • Wiring harness assembly
  • Drilled and slotted rotors
  • Upgraded brake kit
  • Clutch fan
  • Jeep JK Steering stabilizer
  • Oil filter relocation kit
  • Driveshaft Agile 6.0 Diesel v10 5R100/Torque S. Billet Aluminum flange at the Transfer Case
Electrical
  • Blue Sea automatic battery Separator for aux batteries
  • 2x 115ah (230ah combined) Sealed AGM Deep Cycle battery
  • Inergy Kodiak lithium 90ah battery bank, inverter, and 12v charging station
  • 350W Renogy flex panels mounted to custom aluminum square bar frames
  • Renogy shore power/inverter/charger hook up.
  • Blue sea fuse box with fuse light indicators.
  • Blue Sea battery monitor and 12v charging station
  • Renogy solar and batter monitor
  • Renogy solar charger
  • Primary solar charging switch to charge either house deep cycles or Inergy Lithium.
Accessory
  • Bushwacker fender flares
  • Method Grid Wheels w/ full size spare
  • Nitto Ridge Grappler 285/70/17
  • Good year wiper blades
  • Ujoint front bumper
  • Aluminess Tiger Siberian Rear bumper and tow hitch custom fitted to the vehicle with swing away tire mount and deluxe size gear box.
  • Custom auxiliary fuel tank (15 gal) w/ steel built in skid plate and timed auotmatic shut off transfer switch with backlight.
  • Rough Country light bar
  • 2x Rigid Industries D series lights: box side shooters
  • 2x Rigid Industries D series lights: high beams
  • Maxxfan Deluxe adjustable speed bi-directional with remote – Smoked lens
  • 3x Thule Aero blade cross bars
  • 2x Thule square cross bars
  • 4x MaxTrax MKII – Grey
  • Colorado Camper Van automatic actuator driven Pop Top with remote. Includes insulated tent walls.
  • Barn door hammock chair
  • Espar D2 diesel heater with muffler, maintenance kit, and three way split option
  • ARB air compressor TWIN with harness
  • Air lines and two quick disconnect ports. One located on each bumper.
  • Compressor manifold kit
  • Folding exterior side steps for additional roof access
  • Tepui telescopic ladder for interior bunk access and exterior roof access
  • Back up camera
  • Rear LED Baja Designs camp light
  • Front Runner jerry can(s) for grey water and water storage.
Interior
  • Dynaliner and dynamat insulated interior.
  • Customer Planed American Walnut Interior from Aura Hardwoods
  • Leather drop bracket Dining seats and Walnut dining table.
  • Sequoia brand removeable floor mount dining table (Very sturdy and quick to deploy).
  • 3rd person fold away jump seat with seatbelt and 2nd work station/dining table.
  • 21g water tank with customer aluminum enclosure and backlit water level gauge.
  • Tembo tusk fridge slider
  • Snow Master DZ 75L
  • JBL Rear Bluetooth speakers
  • Kenwood touchscreen with GPS
  • Pioneer Cabin speakers
  • EDGE Insight Engine & diagnostics Monitor
  • Back up Camera monitor
  • Level gauge
  • Fitted Packsaddle seat covers
  • Dometic Dual Burner stove, sink, and folding faucet with smoked glass cover.
  • 8020 T track for cargo strapping walnut panel studs, and lower aluminum panel studs. Essentially the foundation for the majority of the interior build.
  • Dimmable led color changing drop lighting
  • Dimmable ceiling mounted white lights.
  • Propane and monoxide monitor
  • Hidden storage cabinets with magnetic locks
  • Custom wood mountain scape with w/ multicolor light backdrop.
  • 2x queen sized beds
  • Exped DUO and SINGLE air pads – Colorado Camper Van original bed cushions included as well
  • Heated shelf for grey water tank
  • Wrappon Electric Toilet system
  • Dual slide galley drawer for interior and exterior use.
  • Blue Ridge overland Storage pouches interior and exterior
  • Kickass 12v oven
  • Joolca hot water shower system
  • 10lb propane tank
AbleGuy
Officious Intermeddler
A service body camper….brilliant! Separate boxes to organize and store all of your gear. ? What a cool rig and nice design. GLWTS.
jlcanterbury
Amazing build. This is a dream platform. The secure and separated storage space offered by the utility box is a game changer. It's the reason I got interested in ambulances as platforms. I love the utility box platform as well - especially one in a narrow size like the one you have here.
In a market that also often contains clapped out poorly converted school buses for well north of $115k, I will say that your build is an excellent value at your asking price.
Your listing is very thorough, so I apologize if I missed this detail, but can you share the loaded curb weight of the vehicle?
KDB
Thank you...a lot of time and funds went into the creation of the rig. Nothing new there but this vehicle certainly presented some unique challenges. Definitely a beautiful one of a kind rig. Theyre excellent platforms. Just under 9800.
