SOLD2019 LOADED Tutleback Getaway
mfisher72001
2019 Turtleback Getaway Trail with EVERYTHING and then upgraded above that.
Located in Phoenix, $18,000
The trailer has a 21-gallon water tank that either is pumped to the outdoor kitchen sink or it has a sprayer attachment that you can use as a hose on the side. I do have an exterior shower platform as well so you CAN take a shower. The inside of the trailer is storage that the top lifts open, or I also had turtleback put a access door in the side as well. The trailer does have the outdoor kitchen with the gas stove. I also added stabilizers on the back to keep the trailer from swaying when the tent is up. Under the tent is another storage area and the tube.
The awning is a Darche eclipse 270. https://darche.com.au/awnings/_item/eclipse-270d-gen-2-aud-eup that I just replaced last year. This awning is very heavy duty, no plastic parts in the hinges.
The tent is a 23ZERO walkabout 87. It is the size of a California king mattress. These tents DO come with a memory foam mattress https://23zero.com/product/walkabout-87-huge-bed/, I also have the annex tent that is zipps up underneath of it, Has room for a couple cots, or we would put a chair in there and make it a easy way to change clothes.
The camper has an internal battery (Currently set for single battery but can put two batteries in, I never needed that extra power with the solar panels) with charging ports located around the trailer, it also has a 1000W with inverter with outlets along with a solar inverter (solar panels are included). This is all you need to charge the battery!
The suspension is also the upgraded suspension to actually allow rough terrain. You can get the swivel hitch for the trailer as well.
More info on the trailer can be found Explore the Getaway Trailer by Turtleback Trailers - Turtleback Trailers
BFG tires all the way around that are nearly new.
seth.c96
