Newbie gmt800 Advice Needed
Overlandtowater
I’m always surprised at what trove1 puts his burb through. I am very near the Ozarks and run them quite a bit and have upgraded as needed. If you have open rear differential throw in a lunch box locker I’ve blown two g80s with 33s and am currently building a semi float 14 for the rear but that is not needed for what most people do. Check out my build thread and you can follow along with what I have broken a you can upgrade as needed.
YukonDebbie
I’ve read through your whole build. Love it! Love what I’m seeing from the country down there. Have not been and we are really looking forward to it. Also Trove1 is the one who’s inspiring me to do this with our truck. Found his videos a month or so back and it really got me thinking about how capable these trucks are in almost stock form. What he’s doing is exactly what I want to be able to do. I’ve actually reached out to him for some advice. I believe a simple easy build is all I need to do. Level keys, springs and shocks, 285’s. The rest will be cosmetic or camping related. If I have the budget for it, I’d like to add a recessed winch mount and winch.
Overlandtowater
Thanks, I appreciate it. I agree with Josh on keeping it simple bracket lifts are ehhh.... If you can find some torsion keys from a 97-03 F150 (oem keys) they will lift you about 3 inches and you can install hummer H2 conversion coils from rockauto and that will also lift the rear about 3" and with those being a 3/4 ton spring rate they will keep you from sagging if you install a camping set up in the rear. spend your money on good shocks and you'll love it.
Overlandtowater
By the way when you head out this summer give me a holler if you come through
Missouri and I may be able to show you some of my favorite places if you can make time.
YukonDebbie
Thanks for the tips and the offer! We will start planning shortly. Have a lot of spots saved that Josh had been and we want to check out.
I’m looking at the Rough County level kit due to cost and it’s gets me shocks and keys. I was looking at the MOOG cargo coils over the h2 springs, once again just due to cost. Not sure exactly which direction I will go yet as far as parts selection, but that’s one idea on the cheap.
toastyjosh
Todd780
OverCamper
Another to check out if you haven't already:
Love this build!
YukonDebbie
Its not cheap but it will ride so much better, coil over conversion for the front.
and this for a winch mount,
I’ve thought about the coil over conversion. Don’t think I’m all in on that yet. For what we are doing.
And that’s the exact winch mount I’m looking at. I am planning to swap to a Sierra grille and bumper. The Yukon/early Sierra front end always bugged me… and my wife doesn’t like chrome so I’ll spring for the work truck model parts.
Overlandtowater
Love this build!
This build is the reason I bought a gmt800 ???
YukonDebbie
Fast forward a couple months. Just finished some parts install. Still more things on the list, but I’m out of allocated money for right now. Big summer camping plans are on hold as I ate through our vacation budget with a back injury I’ve been working on getting corrected…
Went with MOOG heavy duty coils in the rear. Rough Country level kit, used the spacers that came with on the rear. The keys were worthless for me, turns out my driver side torsion bar is wore out. Went through lots of learning about different bars and trying to find new (discontinued everywhere I found)…. I landed on some SuspensionMAXX keys so I could index the bars to compensate. While doing all this, I decided to replace the front control arms.
Also on the list was some different wheels. Wife wanted the truck blacked out, so we will start with the wheels. I wanted a more off road looking wheel, factory 17” spare looks awesome. Still working with some center caps to make fit.
Future plans include a 03-06 Sierra grille and bumper, in black. I’d like to put flares on too, not sure if the wide Chevy style or the thinner GMC style.
2025 deleted member
Or sooner. Mine went out at 160k and then again at 180k. First time I had it rebuilt, second time I had it replaced with a reman'd, waranteed unit from GM.
However I did a lot of towing through the Rocky Mountains. I was pulling a 4,000lb trailer over 11,000' passes 4 to 6 times a month for 5 months of the year.
I never had one make it past 150k but these were work vans and we weren’t doing fluid changes like we should have from the beginning
Linesman1776
