Pop-up versus hard-side height and fuel economy survey
simple
I'm curious to hear what the panel has to say about a couple of real world metrics for these two styles of campers. I can't be the only one wondering. LOL
  • How much reduction in gas mileage have you seen with the addition of a camper (please specify vehicle and camper)?
  • What is your overall height with either style camper (please specify if you have a suspension lift)?
simple
My Spacekap hard-side camper on a 2008 Silverado 1500 4x4 gets 14.5 MPG loaded for a one week trip, highway driving 1200 miles over mountains. I don't have personal data for MPG without a camper but I think it is around 18-19 mpg so I'll estimate the reduction at 4MPG. It is around 9ft tall.
Kevin108
Tires can make as much of a difference as a tent.
2007 FJ Cruiser
20 mpg highway before gear & soft-sided RTT; 18 mpg after.
Went to load range E tires after the Cs wore down. Lost 2 more mpg.
2006 GX 470
20 mpg highway before gear, E-rated MTs, and soft-sided RTT; 15 mpg after.
jmodz
2017 Ford F-150 3.5L ecoboost with a hard sided bel-air camper. I got 14.5mpg average. Before the camper I averaged 19mpg.
2014 Toyota Tacoma 2.7l i4 with a AT overland Summit wedge camper. I got 14mpg with the camper and 18mpg without.
In my experience both had a pretty equal hit on mpg. Both trucks were stock. If I were to buy a camper again, I’d get a removable one so I can commute without it on the truck. Like an Alu-Cab Khaya, Kimbo, or the total composites truck campers.
Arclight
SAR guy
1997 T100 witha Flippac (sticks up over the roofline about 8"). About 15mpg with camper, 16-18mpg greater without the shell.
97heavyweight
2018 Tacoma that is more on the fully built side of things than not. Weight is 6900lbs wet with two people and two dogs. Height is 7'6". I added a wind fairing which help significantly with my MPGs. Currently cruising on the hwy at 55mph I can get 17.5mpg. I think prior to the camper I was at 22mpg at 70mph or so.
GeorgeHayduke
2016 Ram 2500 Cummins: 18-19 mpg empty, 17-18 mpg with a Go Fast Camper, 15-16 mpg with Northstar TC650 and 13-14 mpg with a Scout Kenai.
Groverland
2020 Tacoma 2.7 AT Summit topper. I can average 20+ mpg WITH the topper and mild build-out(150#). Height overall is under 7ft closed, but I'm on stock wheels/tires and my leaf kit was custom made to handle 500# additional constant weight with no change in ride height. I do drive like a grandpa, however.
BajaSurfRig
For my 2014 6.2 gas Super Duty I saw about 11-12 with my FWC Grandby and 9-11 with my Lance 815. Unloaded maybe 12-14.
JaSAn
Grumpy Old Man
Grandby on 2012 Ram 2500, 9 years of gas milage data with camper on and off:
14 mpg with camper off.​
11.9 mpg with camper on.​
loose another 1.5 mpg with winter gas (November to April).​
Truck with camper loaded weighs 7920 wet.​
mkish
2012 F350 crewcab 4WD 6.7 diesel shortbed; Northstar TC800 popup with a full buttwrap. Everything (relevant) is stock. Don't know the height offhand. It's no FWC!
At ~65 mph I get around 20 mpg with a tonneau cover, around 14 mpg with camper loaded. This varies HUGELY with speed. (The spouse gets much less. :p)
Billincamo
60,65,70,75, mph on the highway when you are getting 14.5?
Henrybrowne
