AT CHASER TRAILER FOR SALE (SOLD)
K.V.
FOR SALE: 2011 Chaser Trailer from Adventure Trailers, Inc. Original Owner. Purchased new in July of 2011 and equipped with the following:
  • Chaser Trailer Kit VIN Chassis, Trailing Arm Suspension with air struts, Cargo Box with gas strut assisted lid, Drop Leg Jack, Rubber Matting, Cargo Tie Downs, 2” Rear Accessory Receiver. Standard Powder Coat Color: White with Black Chassis & Fenders
  • Steel Powder Coated Nose Box
  • Two AT Gas Can Holders (Scepter or NATO) for Trailer
  • 19 Gallon roto-mold water tank with 1.25' opening, 1/2' drain plug and pump
  • Stainless Steel sink with drain hose
  • Fiamma F35 Pro 2.2M, brackets with double extension brackets
  • Electric Braked Axle Upgrade with 10' drums, includes break-away kit
  • Utility shelf for Chaser (16.5' x 43' x .75'), shaped and finished hardwood ply with locator pins
  • Auxiliary 12V Power wiring w/ night light, 3 fused outlets, battery tray and hold down
  • ARB Adventure LED light
  • AGM group 31 deep cycle battery
  • Noco Marine Charge On board 10 Amp single battery charger & maintainer with Shore Plug Installed
  • Chaser Tail gate 16' x 32' with locking T-handle latches
  • Multi Axis Coupler, 6000 lb, Class III
  • Swing away tire carrier
  • Transit Slide Lock for Engel MT35 & MT45 Fridges
  • 6 LED Rectangular HD Flood Light 4'x6'
  • 5 lb Manchester propane cylinder
  • AT Custom Aluminum 5 lb Propane Cylinder Bracket & clamp
  • 28" Waynes RV Stabilizer
  • 3 TOYO Open Country ATIII 255/80/17 (purchased 03/2023) on Toyota FJ Cruiser Steel Rims
  • Wheel Adapter: 6 on 5.5 to 6 on 5.5, 2" thick, for use with stock rims
  • Thule track rack and cross bar system, 2 tracks, 6 feet, 6 towers, 3 cross bars
  • Eezi-Awn Series 3, 1400 Roof Top Tent 54' x 96' Beige
Always stored indoors this trailer, tent and all the equipment is in excellent condition, has no known issues and is ready for your next adventure. Located in Houston, Texas. Sold
Additional pictures and video are available upon request.
Thanks,
Kevin Vincent
kv01@comcast.net
njc955
Does this have a table like attachment next to the sink for a kitchen area? Curious how the kitchen area comes together on this trailer.
Nick
K.V.
The table attaches to the top of the fender. There are 2 recessed holes milled out of the bottom of the table that accept two allen-head bolts that are fastened in the top of the fender. Very simple, but it works.
We put the stove on top of the table when we cook.
fireball
These are such nice little trailers. We love our flatbed. The airbag suspension is great - easily adjusted based on total load/weight, and the best part is getting to camp and letting air out of the bags as needed to level the trailer for sleeping and food prep! GLWS!
K.V.
Indeed. It pulls so well too. It’ll go wherever our truck can go with no problem. The trailer brakes are nice to have also.
NatersXJ6
That is shockingly clean and nice. I’m not sure mine looked that good even after I did all the repairs and overhaul and re-paint. GLWS.
