KS Nair
ASKING : USD490K OBO
TRUCK:
Acela Monterra GL 6x6
( 2002 Stewart & Stevenson FMTV 1088A1 Truck Tractor )
HABITAT:
Starlink Mobility Flat High Performance IP56 rated dish that provides in motion connectivity around the globe (subscription not included)
INTERIOR SPECS;
REAR ENTRY
TRUCK:
- 330 Horse power Caterpillar 3126 Engine mated to 3000 series Allison Transmission with full time 6x6
- 150 gallon (568 liters) Diesel Tank that gives an effective range of 1000 miles at 7 miles/gallon
- 47” Tires x 6 plus a spare
- Central Tire Inflation System (CTS) with “highway”, “cross country”, “sand”, “emergency”, “run-flat”, modes
- Electrical winch operated spare tire mount on rear under chassis for easy deployment.
- Cab-to-Habitat access
- 4 wireless camera system with in cab monitor
- Back of Seat Storage boxes x 2 ( 21 Lx 15 Wx 10 H )
- Length 27 ft
- Width 8.4 ft
- Height 12’ 8”
- Weight 28,500 lbs ( fully loaded )
- Length 19’ 9”
- Width 8.4 ft
- Height 12’ 8”
- Body construction – 3.25 in thick high density FRP wall panels for front, roof & floot and 2” thick side walls & rear.
- Closed-cell foam insulation with reinforcement, sandwiched between fiberglass reinforced polyester
- Mount system.
- Meticulously designed 4 point torsion isolating subframe mounting system
- This system allows the truck frame to flex to its maximum articulation during off-road scenarios and isolate that dynamic force from the body
- Rear of body squared to maximize interior space
- Aluminum Storage boxes x 2 ( 53’L x 23’’D x 28’H)
- All around Branch Guards
- Webasto Thermo Pro 90 Heater with Circulating pump
- Provides engine-off cabin heating, hot water, and pre-heats engine for cold-weather starts.
- Cruise N Comfort 12v Marine Grade Air Conditioner Thermostatically controlled ( 10,000 BTU )
- Day/Night Solar Roof vent fan
- Fresh water tank 130 gallon / 490 liter
- External tank fill port and city water connection
- Isotherm© water heater tank with electric element
- Grey water aluminum tank 40 gallon / 152 liter with push button dump valve
- Victron Energy System with 3000W pure sine wave inverter
- MPPT Solar charge controller
- Marine-grade wiring and sealed connectors
- Solar panels: 2040 watts in 6 Panasonic high efficiency panels
- 1000Ah battery pack with 10 Battleborn 12 volt 100Ah lithium batteries
- Energy Management Control System with Bluetooth / Wi-Fi / internet accessible
- Battery main switch with overload interrupter
- shore power connection 120v/60Hz, 30amp
INTERIOR SPECS;
REAR ENTRY
- Outbound Door 24W x 73H
- Integrated deck - 7ft W x 4ft L ( 2 settings )
- Removable High Strength Aluminum Steps
- U shaped dining booth, seats 4 comfortably, converts into ( 37W x 73L )sleeping area
- Memory foam cushion with sunbeam outdoor fabric upholstery
- Storage under booth bench ( 2 units 37W x 20L / 1 unit 33L x 20W )
- Adjustable dining table
- Outbound Panoramic Window ( 67W x 22H ) equipped with Outbound Day/Night Shade
- 3 x 12V outlets
- Cabinetry and Counter: Chemetal Black Aluminum Veneer on Europly
- Drawers and Cabinet Doors equipped with locking finger pull latch
- 3 Double Door Above Sink Cabinet with adjustable shelves ( 75W x 29H X 12 D )
- 1 Double door under sink Cabinet ( 33W x 22L x 23D )
- 1 Single Door Cabinet with adjustable shelves ( 17W x 32H x 23D )
- 1 Double Door Cabinet ( 23W x 25H x 23D )
- 5 drawers ( 24W x 52H x 20D )
- Kessenbohmer Pantry ( 18W x 58D x 22D ) with 5 slide out / soft closure Drawers
- 2 Storage 22W x 18H x 26D with lift up drawers
- Farmhouse Gunmetal black Stainless Steel Sink ( 30L x 20W x 10D ) equipped with Basket strainer, Wood Cutting Board, Basin Rack, Water Trap, Roll-up drying rack
- Kitchen faucet with pull down spray - matte black
- Webasto X100 diesel double burner cooktop
- Furrion Arctic 12V 10 cu.ft refrigerator ( 2.8 cu. ft. freezer / 7.2 cu.ft )
- Panasonic NN-CD87KS HomeChef 4 in 1 Microwave Oven
- LED Lights integrated under cabinets
- LED Multi Color changing Toe-Kick cabinet lighting
- LED Ceiling dream lighting ( warm, white, blue )
- 4 x 110v outlets
- Bed Frame ( 72 W x 72 H )
- Underbed closet ( 73W x 44D x 35H ) with 2 sliding door / 1 hinge door
- Underbed utility storage 73W x 28D x 35H ) with exterior hatch
- Outbound Skylight / Roof Hatch ( 39W x 24H ) equipped with Outbound Day/Night Shade
- 2 x 12v Blue Sea ( side of bed )
- 1 x 12v Blue Sea / 1 x 110v ( opposite bed wall )
- Outbound window ( 36W x 24H ) equipped with Outbound Day/Night Shade
- Wet Bath ( 36 x 36 ) - Fiberglass reinforced acrylic
- Rain Shower System with handheld shower spray - brass, matte black
- Shampoo/Conditioner/ Soap Dispenser - wall mounted
- Sunmar GTG Compost toilet
- Porcelain bidet
- Outbound Window ( 26W x 13H ) equipped with Day/Night Shade
- Pass thru ( 25W x 32 1/2H )
