Badać SS-7 2023 for sale $12k ( price lowered from $14k)Annapolis, Md East Coast
Bandersen777
Upgrade from factory build:
-ARB 2500x2500
-Kickass shower room
-100w solar (1-100w)
-Jackery 240wh
-17” Procomp wheels -12.5 ET
-285 70 R17 AT tires (33 11.50 R17)
-L track installed passenger side w/BuiltRight molle panel
-Badać branded 11lbs propane mount.
-Ram mount for phone/tablet
Wherever you go with your Crossover, SUV or 4x4 your SS-7 will be right behind you. Designed to be versatile and handle extreme use. From never ending highway blacktop to mountain trails and back, a Badac trailer wont let you down.
The SS-7 is designed to be simple, light weight, and affordable built on a 2" square tube steel frame with independent torsion suspension. Weighing in at ~700lbs it can easily be towed by any vehicle with a hitch.
With the exterior of the trailer epoxy coated and finished with high performance urethane elastomeric coating we achieve a monocoque durable skin protecting you from the harshest of elements.
Finding comfort in the most hard to reach places is where Badac shines. With its rugged exterior and cozy warm interior it is available with many options to fit the way you like to explore.
Built on a hand-welded 2" x 2" frame of powder-coated steel, the SS-7 measures 48" x 84", providing ample space for all your gear and equipment. The exterior walls, roof, and floor are crafted from premium Baltic Birch and coated with a high-performance urethane elastomeric bedliner coating, ensuring maximum durability and protection from the elements. So if you're ready to take your outdoor adventures to the next level, the SS-7 is the perfect choice. Whether you're camping, hiking, or exploring new trails, this reliable and lightweight trailer will help you get there in style and comfort.
Frame/Suspension
2" Square-tube Steel Frame
  • Black textured Powder-coating
  • ARK Offroad Tongue Jack
  • MAX Hitch Coupler
  • 2000 lbs independent torsion axle
  • 3" Lift
  • 17" Wheels
  • 285/75R17 AT Tires (33 11.50 R17)
  • 7-Pin Tow connector
  • Rear Hitch Receiver
Body
  • Badać Squaredrop Shape
  • Standard 26x32 camper doors with windows both sides (shades)
  • High end Baltic Birch used throughout
  • Rigid Foam Insulated Roof, Front and Rear Walls
  • Flat Top Fenders
  • Coin Flooring
Interior
  • Low VOC Poly-acrylic finished birch interior
  • Large Rear storage cabinet with exterior access
  • 10 speed Roof Fan w/remote
  • Cargo net Cabinet divider
  • built power system (Jackery 240Wh)
  • Pre-wired for upgrade to simple power system in the future
