Flip-Pac Parts Suppliers List? Windows, Torsion Bars, etc.
Brutsie
Jay18, Have you had any luck on this? I need to replace the whole frame myself. I'm assuming FlipPac didn't have a customer window frame made, so I'm hopping that someone will be able to identify a model number or manufacturer.
I came across these guys, but can't get them measurements until my shell gets back from the paint shop.
https://www.custompickup.com/shop/index.php?l=product_list&c=2772
Broken Rear Window hinge
The hinge on my rear window just busted. Most of the rivets have come out. Can anyone recommend where I can get this fixed? Can any camper-shell repair place fix this?
Hi. I am wondering if you found a model number for the flippack rear door replacement. I had a significant mishap that pretty much destroyed mine including the frame of the back door is damaged. Thanks for any help.
scantino
If you want I could take a pic or two.
Does anybody have any info on replacement hood pins? I can't seem to find anything.
Also, there seems to be a wrench/bar that attached to the torsion bar for easy open/closing. Does anybody have any idea where to find a replacement? I currently have to use a stepstool and my bar hands and its a huge pain.
Thanks!
scantino
Thanks!
Well, I found some photos, but no luck with replacement parts.
Hood Pins:
Torsion Bar Crank:
WOODY2
Hood Pins:
Torsion Bar Crank:
One possible work around would be weld a large nut to the face of the splined torsion bar then you could use a large breaker bar and socket to open the lid. I'd suggest not covering the actual splines incase you ever source a replacement. You won't need the hood pins to transport it back to your place.
scantino
Not a bad idea but I don't know how to weld. It's already on my truck, I'm just looking for the pins to take it out!
scantino
more photos of the hood pins
highwest
I think this thread over at Tacoma World has drawings of the original hood pins that you could take to a fabricator and have made up. I’m sorry I’m unable to find the specific post.
Frontcountry
I am getting the FlipPac rear glass replaced at Central Glass in Midvale, Utah. 7985 S State St. 801-561-2213. About $260. They are the only place that I have found that could help.
4x4Hoth
Poptop Overland in San Diego, CA recently posted they changed a torsion bar and hinges fyi.
