Peak Hard Sider welded aluminum expedition trailer norcal. REDUCED
2019 Peak Trailer​
Reduced $22,500. Cloverdale, Ca.
Under 2700 lbs.
Welded and riveted heavy gage aluminum and insulated aluminum sandwich panel construction. Load rated aluminum roof rack and shell. NO PARTICLE BOARD OR WOOD!!
Mechanical:
Off-Road independent suspension with coils and double shocks. Rides great in the dirt. You can leave things in the counter and they are there when you stop. Electric brakes and mechanical parking brake. Mud tires. Stabilizer jacks. 2" Standard Ball or offroad coupler. Uses Australian/ Timbren 4 bolt hitch pattern.
Electrical:
110V shore power/ 110V inverter power/ 12v systems
Two AGM batteries and 2000W inverter/ charge controller.
100w solar charging
Full LED lighting
Water:
32 gallon fresh and grey water tanks with skid plates. Tankless on demand water heater. Hot water sink. Hot water shower
Comfort:
Wired for dometic AC. Front opening window with solid and partial blinds. Pop up roof that is 8 feet high with zip-out canvas sides and screens.
Kitchen:
Kitchen accessible by heavy gage aluminum door with gas struts. Pull out sink and two burner gas stove. Pull out fridge tray. Power center. Storage compartments and pull out tray.
Perfect for 2 adults and one child. Bunk conversions available for sleeping up to four adults.
Email: paulmeese@att.net
Perfect from the beach to the desert.
V45W_Proto2.5
