Habitat build
gator70
Few folks can't afford the total composite shell at $35,000.
And I need 14ft long on the frame, with 16ft long in total.
General idea where I start.
gator70
I'm looking at all options.
I prefer aluminum skeleton and aluminum sheet exterior.
Weld the skeleton, use sikaflex for the exterior lamination.
Now, even that is expensive.
I have noticed used 16ft box truck bodies in fair condition for $2,500.
They have aluminum posts (they call stakes, aluminum siding, steel I-Beam floor frames, thick oak floors.)
They have a construction that lends itself to alteration with fabrication. On the surface the size is too tall.
gator70
Spring mounts for the sub frame is mostly custom fabrications. I noticed the lower bracket is bolted to the frame, while the upper bracket is welded to the subframe.
I prefer to buy brackets. If anyone knows where I can get these, please speak up
I will post a lower and upper bracket I consider.
gator70
For the subframe, some folks pivot the frame in the center close to the cab and at the end of the sub frame on a horizontal bridge beam.
So I'm not looking forward to that expense. However I did find reasonable pivoting greased pivots sold as dump truck hinges.
Seems like the weight category is sufficient.
gator70
To reduce height dimensions I will use iron angle iron rather than steel tube for the subframe.
DanoWall
