Montero gen 2.5 Suspension Motion Ratios
Toasty
Does anyone have the motion ratios for Gen 2.5? I am looking to have shocks re-valved. Thanks
I changed mine, you just give your measurements and angles to your tuner and they'll figure that out for you.
total link length (axis of the pin at the frame of the trailing arm to the front bolt at the axle)
pin axis to shock
shock angle
What shocks do you have that you're trying to revalve?
RThompson
pin axis to shock
shock angle
It’s a spicy home brew 2.5”’Performance Elites from a Dodge 2500. I am shortening the body and shafts.
RThompson
Fronts are custom 2.0 also with high and low speed compression adjusters
Toasty
Nice! I think on my '98 I'm going to do something similar. My son has standard remote res Fox 2.0's on his '99 and it rides pretty nice, I'm either going to get the Gen 2 Pajero shocks from King or do some custom work and fit up some coilovers to be one better than the kid.
cham
I was under the impression King Shocks only made solutions for Gen 3/4 Paj's; are you talking about a custom setup for your Gen 2.5?
Toasty
King makes a set for the Gen 2 but I'm also considering doing something custom to be a little better.
KRS-20001-274Mitsubishi Montero 91-00 Front 2.0 ShockNon-AdjustableStockFront2.5" Remote Reservoir
KRS-20001-275Mitsubishi Montero 91-00 Rear 2.0 ShockNon-AdjustableStockRear2.5" Remote Reservoir
zhukoveli
