Roaming Lost: x3 Locked 1990 Toyota HDJ81 (80 Series)
roaminglost
Most of the stuff on my short list is maintenance. So, I'm currently getting my front knuckles rebuilt. But while they're apart ill be upgrading to the later 80 series rotor and calipers for some added braking power.
roaminglost
The power system for the truck will be this Expion360 kit. I plan on doing a custom electrical system but this fits the bill perfectly.
1HaytchZed
The first thing I had done was a PDI intercooler and trans cooler.
View attachment 801585View attachment 801586
Also added some Corbuea GTS-II seats (with heat)
Waiting on gauges, I had to put an EGT gauge in for now so I'm using a GlowShift. I'll be swapping to REDARC gauges hopefully soon.
Also added some One Stone armrests. pretty easy to modify to work with any 80 series.
What modification did you make to fit HDJ81? I could use one for mine.
BEBs done?
roaminglost
Upgraded the catch can to an HPD from Aus. Right off the bat, my blow-by seemed almost non-existent now.
roaminglost
knuckles got rebuilt so while it was apart I had them upgrade the rotors and calipers from a later 80 series. The difference is pretty noticeable in person.
OLD...
NEW...
Ancientsojourners
