Plywood shell/skin. Seal- spar urethane both sides or just one?
drewspuppet
So I’ve got a pretty large trailer build 19’x7.5’ and right now have a bunch of luan sandwiches to assemble and finish.
Due to cost I’m wanting to skin in 1/4” mdo plywood and seal/paint. It’s something that if doesn’t work out I can fix or change down the road.
2x2s, 1.5” foamular and super thin luan.
Would using the urethane on both sides of the 1/4” help prevent warp, etc? Needed?
Thank u for your info
rruff
I built a camper like this over 20 years back. I'd highly recommend epoxy-fiberglass as your exterior coat over the luan, then paint. You can do most of that before you assemble the panels if you wish.
Teardropper
If I understand, you are asking if the inside of the sheathing should be varnished on the interior side before attaching to the framework.
I'll vote no.
I think sheathing should be attached using TB3 (and screws or crown staples), and any surface treatment will negate the glue's ability to grab the wood. I suggest TB3 instead of TB2 because it has double the open time to work with.
I sure didn't get any warping on my interior 1/8" BB sheathing:
Tony
P.S. I swear by Minwax oil-based polyurethane.
V45W_Proto2.5
