Torsion-Free Sub-Frame
PacificNorthWestJeeper
Blissfully Lost
Thanks MOG, i've seen that and a few other kits, but all I need is the solid 4, 5 or 6 inch solid round bar then bearings to slip over the bar to make my own. I can bend, cut and weld up everything else.
I can also pick up some solid round bar, so really just some heavy bearings of brass inserts like others which can ride on the solid bar.... If anyone has a lead on that let me know...
Blissfully Lost
I thought about using a spring equalizer/load equalizer like you would see in big tandem axle trucks but the bushing hole of the ones I have found are too small.. Thinking i will need to use 4-5 inch solid round bar...
Equalizer example:
Alloy
.........4,5 or 6" rd bar? How many hundred tons will the habitat weigh?
Blissfully Lost
Alloy, lol, like it... Not going to have tons but a good amount of weight...
Im even thinking about using a pillow block kinda like this for the 4 contact points, obviously don't need high heat, just an example......
. Any better ideas out there?
SkiFreak
Crazy Person
Sorry, I could not resist... :)
As with all builds of this type, the mounting system needs to suit the specific vehicle and intended purpose.
If it does that, all's good and global harmony is maintained.
