Earthroamer Continental MPT 81 in Winter
IdaSHO
IDACAMPER
I’m no Overlanding Adventure Man (TM) that combs the great white north deep into the winter months…. That being said, I took my rig on a 10 day elk hunting trip in the Eagle Cap mountains of NE Oregon last Nov. We were about 20 mi deep into the mountains that is primarily dirt access roads that get narrow, steep and twisty in many places.
When we arrived there was a few inches of snow fall from the previous week and it was starting to snow again. The first 3 days it snowed about 2 feet. Since we were hunting and not in a hurry to head back down the mountain, we didn’t think much about the drive back. However, after day three and no sign of elk (we believed the snowfall pushed them to lower elevations), we started thinking about making the trek back down.
I’ll be honest, we were nervous to make the drive down. Especially after hiking back to camp one of the days and seeing multiple freshly fallen trees across the snow covered access road we needed to return on. It was remote and our only comms with the outside world required use of our Garmin Sat messaging devices.
Anyhow, long story longer…. I brought a set of chains just in case, but never used them. The MPT 81s worked amazingly. We had to take an alt route down the Mtn that was about 30 mi. At one point we had to do one of those super tight Austin Powers u-turns and I managed to get the front end of the truck off the side of the road and into a fairly deep snow ravine. With TC enabled, the tires hooked up and climbed out.
As you can see, i opted to use a Northern Lite camper, so it’s not very light load. But again, the tires did great and was able to keep the chains in the bag for this trip.
Looks good.
No surprise deep lugged tires worked great in deep snow.
Id be far more concerned about travel on hardpack and icy roads with such tires.
lucilius
Are the Alcoas 10 @ 225?
Alcoa
Product Part Number 89U63x (my newest wheel is an 89U631, they've changed the #'s a bit over time)
Wheel Size (in) 22.5" x 9"
Mounting System Hub Pilot
Bolt Holes 10
Bolt Circle 285.75mm
Bolt Hole Diameter 26mm
Hub Bore 220.1mm
Approx. Weight (lbs) 48 lbs
Outset (in) N/A"
Inset (in) 3.12"
Max Load (lbs) 10000 lbs
Max Cold Infl. (psi) 130 psi
Valve Stem TR555E
Alloy
Alcoa
Bolt Holes 10
Hub Bore 220.1mm
Outset (in) N/A"
Inset (in) 3.12"
Valve Stem TR555E
Do you have 10x225 to 10x285 adapters?
lucilius
Yes. The SRW conversion required wheel adapters, the name of the manufacturer escapes me. I believe they are no longer in business. There are a few companies out there doing custom wheel adapters esp. given the growing number of SRW 550/5500 trucks/campers/brush rigs/etc. Perhaps the ideal route would be finding a new rear axle but I haven't looked that hard and found one that is compatible and, though even fully loaded I am always well below GAWR, can handle more weight than my current one (Dana S110) to justify the cost and complexity of a swap. I am sure there is a better axle solution for the F550/5500-type chassis trucks, esp. if your weight is approaching GAWR, but I haven't found one. A key feature that would be worth finding is a locking differential(s), which to my knowledge is not available for the 550/5500 as configured.
Air locker standard, NoSlip (Detroit) and LSD available, “CTIS ready”.
Cost:unknown, but undoubtedly not cheap.
mk216v
Der Chef der Fahrzeuge
In my research, there are some true winter tires available for 19.5” and 22.5” wheels (like Alcoa super single); Continental HDW2 and Bridgestone W919. One issue though is that the Alcoa is a 10x285.75mm when the Ford F550 for example is 10x225mm rear (and also the same 10x225mm up front with the OEM Ford spacer—remove that spacer and the front hub is 170mm—I think 8lug vs 10lug??). Per Earthroamer, it’s not easy to move between their 3pc Hutchinson (which have their own adapters for some reason even though this WA-1090 Hutchie is 10x225mm) and the Alcoa super single. They’ve had many customers ask for this butI’m told that studs have to be pounded out to swap between their adapters.
One other option (not as ideal as true winter tires) is having an MPT tire siped—Pomp’s Tire says they can do this. Old client has 40” Toyo M/T’s that were siped on only center lugs and he says they perform well in Montana winters.
Also, for very acute instances, AutoSock from Norway makes their snow socks in 335/80/20 fitment, but say that max speed is 25mph, and when you hit bare pavement you need to remove the socks…so this solution is only for getting caught in a snowstorm vs unrestricted winter travel all season long (like I’m looking at).
seth.c96
