Ultimate Overland Rig - 2022 4x4 MB Sprinter professionally built by ZENVANZ - SOLD
dangerbus
BryDanger
Built in early 2023 by the pros at ZENVANZ
This rig has everything you need (and more) for true offroad/offgrid/overland use of your van and also does it in comfort and style.
Lightweight, no rattles and built to outlast the van itself!
EXTREMELY light use and in perfect condition.
Still under factory MB warranty and less than 10k miles.
Interior
  • ZENVANZ curved bamboo/aluminum interior cabinetry (NO LAMINATES)
  • Black powdercoating/anodizing
  • Bamboo ceiling slats to enhance circulation
  • Slatted divider with hanging boxes
  • Sound deadening
  • 4-season insulation using 3M Thinsulate
  • USB ports and 120V outlets
  • Overhead LED lighting on dimmer, 3000K warm white (10)
  • Upper cabinet LED task lighting on dimmer, 3000K warm white
  • Garage lighting, LED 5000K neutral white
  • Reading lights w/ USB (2) at bed
  • Vitrifrigo 180 2Drawer Fridge/Freezer
  • Induction Cooktop
  • 3000VA Victron inverter/charger
  • 400Ah Victron lithium battery
  • Integrated Victron system monitoring and control
  • Garmin Overlander & PowerSwitch control system
  • DC/DC charging via alternator
  • 15A shore power charging at rear bumper
  • 2Tek2 Vinyl flooring w/ aluminum trim
  • Coosa Insulated sub-floor
  • Step extension at sliding door
  • Rixen hydronic heat and hot water system
  • 30-gallon interior potable water tank
  • Guzzle H20 Stealth water filtration w/UV
  • 7Gallon sink gray tank
  • Interior flush floor mounted hot/cold shower
  • 11Gallon shower gray tank w/ motorized dump valve
  • Aquor water fill
  • Shurflo electric water pump
  • Shuksan overhead cab shelf
  • Hybrid memory foam mattress
  • Insulated window shades
  • Rolef bug screens at slider and rear doors
  • Carbon monoxide alarm
  • Fire Extinguisher
  • ZENVANZ table arm with bamboo table
  • Thetford cassette toilet
  • Insulated black-out window covers and cab partition
  • Arctic Tern Skylight/Roof Hatch
Exterior
  • 300W Walkable PV solar panel and 30A Victron charge controller
  • Exterior shower on back of water cabinet (w/ curtain and bamboo mat)
  • Stainless steel gravity water fill
  • MaxxAir 7500k smoke roof fan
  • CRL T-Vent Windows
  • Flarespace Flares with 10×30 bunk windows
  • 5x Legend Black Rhino
  • 5x Falken AT3 tires
  • TerraWagen Mondo Mudflaps
  • Van Compass 4.3 Suspension upgrade
  • Fixed Aluminum Running Boards driver and passenger side
  • Pedal Box throttle instant tune
  • Bugscreens at Slider and Rear Doors
  • ZENVANZ full-garage slide out gear tray
  • TannerRack roof rack w/ 5x LP9 Lights
  • Fiamma F80 Awning
  • Extension step at Slider Door
  • Load Lights
  • Owl Vans Sherpa Cargo Carrier
  • CA Tuned Front Winch Bumper with Warn shackles & LP6 Lights
  • Terrawagen Fender Flares
  • RoamBuilt side steps
  • CA Tuned Front Winch Bumper with Warn shackles & Vision X lighting
  • Warn Zeon Platinum 12S Winch
  • Camco Taste Pure water filter at fill hose
  • Starlink capatability pre-wired
  • ARB twin motor compressor
  • Agile Offroad engine skid plate
For more photos, here's the van on the ZENVANZ website.
Write with any questions.
Van is located in Portland, OR
Asking $208,000 or best offer.
This build was $268k as a full/custom ZENVANZ build (in early 2023).
dangerbus
BryDanger
Beautiful interior. But so sad, no inside bathroom.
There is both an interior toilet and shower in this build.
If you're referring to a full height "Wetbath" (especially in a 144wb), we find it to be a huge waster of space... but to each their own.
MsRandiCook
It may not be important to guys, but a fully enclosed warm wetbath is a necessity for women. Showering outside is not fun when it's cold.
dangerbus
BryDanger
Like I said, to each their own (though I know many women who would disagree with you). ;)
This van does have an interior shower - because we all agree about the showering outside bit (especially in negative temps).
This is a large part of why we eventually decided to start designing/building vans for others... because everyone should be able to have their perfect van/layout, whatever that happens to be! ;)
dangerbus
BryDanger
Those beautiful rounded corners really set you guys apart. Zenvanz make my normally fairly rational brain buy lotto tickets.
Thanks! I assure you that while beautiful, those curves are for function (and I still have scars on my head to prove it)! ;)
Also... we try to keep our builds very affordable. They are more than an assembly line build (but they also won't start falling apart in a few years) but less than most other custom builders. Happy to support your build if we can!!
Keyne
GLWS. ZenVanz would be my choice if I didn't already have a van. Not only are they beautiful on the outside but look at the wiring, etc.; works of art IMO. Also, I really like that the cabinets, walls, and ceiling can be unbolted and removed for inspection, repair, maintenance, or adding additional items. Made by people who travel for people who travel.
dangerbus
BryDanger
Our team does amazing work and for all the right reasons!
We appreciate those who can appreciate the difference! 🤙
V45W_Proto2.5
