7.3 Quigley 4x4 E350 - 25k miles Camper- Sold
Cummins_expo
When you have 2 low mile vans you have to decide which one to keep- Posting this on expo first and will post elsewhere after the holidays.
Prescott AZ- Sold
2002 E350 Extended Body Quigley 4x4 7.3 Diesel with 25,552k miles - I know the word Unicorn gets used a lot but to the Ford E-series fans this one truly is. It started out life as a rescue unit for a small volunteer fire department. So not your sit and idle big city ambo. Power windows, doors and mirrors, cruise control, parking break rev control
The entire electrical panel was thinned out and isolated from main starting system.
50 amp Dc to Dc with mppt Solar Controller - Kisae
2000 watt Inverter/Converter/Charger Kisae
2 130 Amp hour AGM batteries
250 w. solar
Autoterm Diesel Heater plumed to tank
Aero Tank 40 Gallon Quigley cut tank
25 gallon water Tank
Fold Away flush mount sink
Jacknife couch bed from a Sportsmobile
Led lighting
Sirocco II 12v fan
Vinyl plank flooring
rear heat and AC still operational ( with unit running)
Some simple custom wood work with keeping some of the Ambo cabinets
Fiberglass top cut and reworked to remove scene and emergency lighting ( wiring for scene lights still left intact to swap out to something like rigid flush mounts )
5'6 ish standing height - Plan was to cut the roof area near kitchen and install a 23zero Kabari X RTT and make a crawl through but give full height as well. Would also provide a second sleeping area.
Brand new Falken Wildpeaks
You could run this rig as it sits or be the foundation for a bigger build. We can assist with full build out or complete gut and change CAD designed and CNC cut if you desired through 365 Camper in Prescott
gp01
