BigSkyBrad
Walking past our truck today, I noticed to my horror that the fuel tank is stoved in, and subsequently the fuel pump assy is mangled! Weirdly, every section except the two ends have some degree of inward deformation.
I figure it is one of two things...
a) someone has backed into it
b) it has vacuum imploded
I have found an alloy replacement tank, and OEM Bosch fuel pump, but if it was a vacuum issue, I'll need to replace the breather check valve.
Does anyone know the part number of the valve, MK_________ ? Or would any simple two-way check valve do? (far cheaper option)
Cheers in advance
Cheers in advance
