2022 RAM 5500 Composite "Super Camper"
StenchRV
Finally some time to catch up!
Got home from the "big" trip and needed to catch up on home life.....and get my hands looked at. A few injections, pills and an upcoming surgery hopefully will bring the hands back around. I pushed a little too hard to get Snowball finished before the trip and my already hard worked hands let me know the "limit" OH WELL....life.
FINALLY had time to take EVERYTHING out of the rig and get it weighed. We never had the chance to weigh empty before we departed on our 8000 mile journey, I weighed it full at a truck stop a few miles down the road from our house as we departed north , just to be safe. We did weigh the rig 4 other times during the build so I was pretty confident we would be just fine.
EMPTY except for me, 170 LBS, full fuel about 70 ish gallons and fuel DEF 8 gallons ISH. 6 gallons of water in the water heater.
Here is the full weight ticket as we rolled out the door in late July. Myself, my wife, clothes for 2 different seasons, 100 gallons of water, full fuel 70 ish gallons, def, spare parts, LOTS of tools, camping gear, good amount of food, extra wine, beer and bourbon :)
Plenty of margin with the 19,500 LB GVWR. I am not sure we could make max weight unless we built something else onto the rig.
The interior storage space was about 2/3rds full.
A lot of "stuff" fits into the outside boxes!
The plywood and the black maxx traxx did not go with us. Still need to make an exterior aluminum mount for the Maxx Traxx.
We had a compact set of traction boards :)
Getting some small "upgrades" done on the rig this month. The list was very small after our long trip.
Also knocking out the second oil change and 3rd tire rotation, getting ready for a Christmas run to Little Rock.
CHEERS!!
Vance Vanz
CHEERS!!
Thanks for the weight info Craig. I can't wait to see which one of ours beasts is slimmer 😁.
I'm sorry to hear about your hands; I know you had previously mentioned them. I hope everything goes smooth with the surgery. If you need somebody to pick your nose, just give me a ring 😆.
Brad_UT
Craig,
Here are some pics of the antenna mounts and ground straps we were talking about.
StenchRV
Communication radios- We wanted a compact unit preferably hidden away. We saw this unit, Midland MXT575, on a Jeep we meet while on our long west trip. We decided to upgrade the stock antenna, hopefully for better range.
THANK YOU Brad, see above, for the antenna mount link! :)
We decided on stainless steel and with some minor tweaking it fit perfect.
CHEERS!!
UglyViking
Looks good. I know in the 2/3500s there is normally a jack and funnel under the pass seat. I take it that stuff wasn't there for the 5500 or did you just strip it?
StenchRV
Does not exist for the 5500. I carry a 20 ton jack, and impact sockets, under the drivers seat :)
Considering my rear axle weighs in at 11,000 LBS loaded...figure the jack is my responsibility! LOL!!
StenchRV
What a shock! :)
Finally had time between trips to rotate the tires and install the rear shocks.
During the tire rotation I found a small slice on a rear tire. I think it happened on the last trip, not sure how.
Sent a picture to my tire rep and he said do not install on the steer, that is where the 1/2 worn tire was going. We decided to purchase 1 new tire, grab the new spare and have 2 new rear tires. Better safe than sorry. The fronts are only 1/3 worn after about 12500 miles. The rears will catch up as they were worn about 50% after the same 12500 miles. We rotate about every 5000 miles.
Back to the grind....CHEERS!!
StenchRV
Added a little storage. We have a long trip coming up and wanted a place to store some of the spare parts we carry, move them from the drivers side under box, plus carry a few more parts. Mostly lightweight stuff, but still takes up space. We had steel placed in the rear wall when we had the box manufactured. Drilled and tapped 1/4-20 SS bolts into them and also Korapoped the 8020 frame in place. FYI Black Korapop is FUN to use....WOW!
Owl Monster Box with 2 shelves inside. Mounting Maxx Trax behind the tire on the far left, for now. Will have a custom molle panel made to cover the 8020 frame to mount any additional items we think we might "need" :)
CHEERS!!
mog
Kodiak Buckaroo
CHEERS!!
I see you used block and tackle pulleys in the shop for raising/lower your wheel. Is that the way you do it on the road also?
Awesome build, great photos and lots of useful information here. Thanks, 🏆
Vance Vanz
CHEERS!!
As usual, looking super clean Craig (y)!
Thanks for sharing the new additions.
You gotta quit raising the bar, I can't catch up ;)😁.
seth.c96
