MJCake1
For Sale:
2015 All Terrain Warrior Mitsubishi FUSO FG4X4/FG72S
Overland Expedition Truck
☆☆☆ PURCHASED BRAND NEW 2017 ☆☆☆
Introducing the 2015 All Terrain Warrior (ATW) Mitsubishi FG4X4 overland adventure truck!
This top-of-the-line overland expedition vehicle is based on the 2015 Mitsubishi Fuso truck and was created by Global Warrior of Australia in association with Sportsmobile West. It’s the perfect vehicle for exploring the most remote locations on Earth in complete comfort, with all the conveniences you’ll ever need.
The ATW Mitsubishi FG4X4 is equipped with a reliable and fuel-efficient Mercedes 3.0L dual turbo diesel engine that produces 161 hp and 295 lb-ft of torque. It has a decent towing capacity so you can bring all your gear along for the adventure. The ATW Mitsubishi FG4X4 also features 4WD and a limited-slip rear differential to tackle any terrain.
The interior of the ATW Mitsubishi FG4X4 is just as impressive as the exterior. It features a spacious living area with plenty of room to relax or entertain guests. The kitchen is fully equipped with everything you need to prepare meals, including a fridge/freezer, stove, sink, and plenty of storage space.
The galley is immediately opposite the entry door with a 12V Vitrofrigo stainless steel drawer style marine grade fridge/freezer, Dometic 2 burner denatured alcohol stove, Dometic single sink with fold down faucet and glass top. 4 teak door storage cabinets. Opposite the galley is the bathroom with a pop-up shower and porta-potty. The bathroom has hot water. Air conditioning and diesel heat make this a comfortable rig all year.
At the rear of the cabin is the queen bed with storage underneath. Forward is the marine-style dinette with panels to convert it into a twin bunk. An accordion baffle connects the cabin to the cockpit, and the Lagun teak wood dinette table swivels into this space to get out of the way of the bed. Sleeps 4.
The electrical systems on this rig are impressive and make it such that as long as you have diesel, water, and sunshine, you can stay out as long as you like. The two 240Ah AGM batteries for the house are kept charged by 4 100W solar panels. A Magnum 2800 charger/inverter provides AC power when not plugged in to 30A shore power. Most systems are 12V marine-grade rather than AC powered.
SPECS
2015 Mitsubishi Fuso FG4X4/FG72S
All Terrain Warrior
Mileage: 52460 miles
Engine: Mercedes 4P10(T5) 3.0L 161hp/295lb. ft. of torque diesel engine.
Type DOHC, 4-cylinder, 4-stroke cycle, water-cooled, turbocharged, intercooled diesel with 4 valves per cylinder
Displacement 183 cu. in (3.0 L)
Max. output (SAE, gross) 161 hp @ 3,400 rpm
Max. torque (SAE, gross) 295 lb.-ft. @ 1,300 rpm
Standard Mitsubishi Fuso DUONIC® 6-speed OD AMT with transfer case
Type Single-reduction hypoid, limited-slip (rear)
Ratio (std/opt’l) 5.285/5.714
Suspension: Parabolic leaf springs for a smooth ride experience plus 6-way air seats with massage.
Wheel specs: Super Single Steel wheels
4 NEW Toyo M608Z Hyparadial 285/70R 19.5 tires
Exterior:
GVWR/GCWR 14,050 lb./21,765 lb.
Wheelbases available 134.4″
Overall length (cab/chassis) 227.8″
Usable cab to rear axle 104.8″
Rear Aluminess bumper with dual spare wheel cradle
2x WARN 16500 lb winches for wheel lifting and vehicle recovery
Auto retracting entry step
2 Fiamma awnings
Fit body to chassis utilizing ATW mounting system.
Interior:
Front cabin pass-through connection to camper.
Pop-top roof with auto-electric level lifting system
Queen-size rear bed with storage under.
4 person dinette converts to double bed
Dinette table mounted on Lagun arm
Interior storage for gear/supplies
Plus
Front & Rear cameras viewable via Kenwood Sound System Garmin Navigation Touchscreen in cab
Zamp SCC with 400 watts Solar
2 x 240 Ah AGM batteries
Circuit breaker distribution panel
VSR dual battery system with emergency parallel
ADR LED lighting on module
7 x LED internal lights
3 x LED external lights
5 x LED bin storage lights
1 x USB power socket next to bed
1 x AC power socket in front lhs locker
1 x DC power socket in front rhs locker
Adjustable safety temperature valve
Variable speed water pump Shurflo
Vanity basin with flick mixer/shower combo
Hot & cold external shower
SMEV S/S sink with glass top
After market Ceramic Tint on all Cab Windows
Manual Towing Mirrors
Aux Transmission Cooler
Handling Package
Driver/Passenger Air Bags
4-Wheel Drum Brakes w/ABS
3.0L Dual Turbo Mercedes Diesel
Manual or Automatic 5-Speed Transmission
14500 GVWR Package
Engine Block Heater -Electric
140/Amp Alternator
Cruise Speed Control
Insulation Noise Deadening Package
Warn Locking Hubs
55 Gallon Fuel Tank
SMB Owner’s Manual
Custom Kenwood Audio w/Sub & Amp
Ravelco Security System
OBD II Blutooth Engine Diagnostic Monitor
Leather Gray Interior
National AirRide Leather Seats
75 gal. Fresh Water Tank 50+25 separate valved
15 gal Grey Water Tank
Thetford Porta Potti (new)
140 L Vitrifrigo Refrigerator Freezer
Loncoin Floor w/removable overlay Carpet
Cabinets - Teak Doors
Corion Countertops
Venting Shaded Side Windows
Lagunn Multi Position Dinette Table
Espar Diesel D-5 Hydronic High Altitude
Engine block heater
Exterior Shower
Titan Gun Safe
30 Amp Shore Power w/ Cord
AGM 420 Amp Batteries (New 6/23)
Magnum 2800 Watt Inverter
Zamp Solar Charge Controller
400w Amorphous Solar Panels
Sink w/Sprayer
12v Shut off
Smoke & CO2 Alarms
110v Interior/Exterior Outlets
Exterior Area Lighting both sides
Electric Penthouse Top
Penthouse Bed
2 Fiamma Awnings
Aluminess Side Ladder
Aluminess Front Bumper
Aluminess Rear Bumper Dual Tire Carrier
Aluminess Roof Rack
2 Warn 16,500 lbs Winches front and rear
Retractable Steps
Fender Flares
Yaesu 857D HF VHF UHF Radio
Kenwood Garmin Mapping
Extreme Air Magnum Compressor 140 psi with tank
Rigid LED Lightbar on bumper
Hella Fog Lights in Aluminess Front Bumper
Hella Flood/Spot lights on Roof
Rigid LED Back Up Lights
TOYO M608Z Tires
ATW Reversible Super Single Steel Wheels
Hitche Recievers front and rear
Extras Included:
SafH2o sediment/carbon/UV 12V Portable Water filtration system included!
2 Maxtrax Vehicle Recovery Traction boards
ARB HD Complete Recovery Kit + 32k pound snatch strap.
Jet 20 ton Pneumatic Jack + Chicago 3/4” HD Impact Wrench w/ 41mm socket
Custom Aluminum lockable Generator box with hitch reciever plate
Partner Steel 2 burner Stove for outdoor cooking.
We-Boost Cellphone Booster
Garmin InReach GPS
Extra rebuilt Espar DW5 Hydronic heater
Jensen 19" 12v TV/DVD Player
ATW is in incredible shape and stored in heated shop.
Reason for selling; Getting older and need $$$ to build a cabin.
Serious Inquiries Only:
Full Video Tour
ph: 307.340.0325
email: mmoverland@protonmail.com
SPECS
All Terrain Warrior
Exterior:
2 Fiamma awnings
Interior:
Plus
Handling Package
14500 GVWR Package
140/Amp Alternator
Warn Locking Hubs
55 Gallon Fuel Tank
SMB Owner’s Manual
Corion Countertops
Engine block heater
Exterior Shower
Titan Gun Safe
Sink w/Sprayer
12v Shut off
Smoke & CO2 Alarms
Penthouse Bed
2 Fiamma Awnings
Aluminess Roof Rack
Retractable Steps
Fender Flares
TOYO M608Z Tires
Extras Included:
Garmin InReach GPS
Full Video Tour
ph: 307.340.0325
