2004 Land Rover Discovery II
Super clean inside and out. Ready for hauling kids to soccer practice -OR- better yet, kitting out as a cherry overland rig.
ENGINE:
Replaced original (slipped bearing in bottom end) with engine refurbished by County Rove in Portland, Oregon. Here's what they had to say about the engine refurb:
"Its a 4.6L V8 from a P38 Range Rover which are more sound blocks than the DII 4.6L blocks. . .thoroughly cleaned/gone through:
1) Machine/decked heads according to spec/tolerance, port/polish, new stem seals and head bolts
2) New gaskets, o-rings, seals (including front/rear mains)
3) New timing chain, sprocket, gear and water pump
All work was performed out of the vehicle, on an engine stand."
Swapped out at 110,841 miles
Current mileage: 111,742
TIRES:
BFGoodrich All-Terrain T/A K02 285/65/18 tires (including spare)
SUSPENSION:
Old Man Emu suspension kit (front and rear)
Terrafirma track rod
NEW:
Serpentine belt
Power steering pump
Engine mounts
Air inlet hose
Auto transmission filter
Spark plugs
Spark plug wires
Header seals
Header-exhaust seals
ABS modulator shuttle valve switch
Transmission XYZ switch
Coolant overflow/return line
Snorkel assembly (MANTEC)
Passenger cup holder
Fuel door latch
Rear hatch retracting step
$15,500
Grants Pass, Oregon
Just back from a 20 day rafting trip through the Grand Canyon - apologies for any missed correspondence. The Disco is still for sale.
Maddmatt
Do both sunroofs work? Any grinding noise? Do they leak?
3 Amigos - or were they vanquished when the new engine went in?
In and out of 4lo smoothly?
oskarf150
